Missing mkfs.ext4 on Asuswrt-Merlin AC RT-5300?
Taylorrr
Hello,
I am running an AC RT-5300 with the lastest and great version of Asuswrt-Merlin (384.4_2).
I was under the impression that this should support mkfs.ext4:
https://www.hqt.ro/how-to-format-usb-drive/
(Apologies for the pastbin link, but forum's use of CloudFlare seems to block any posts that have code like things in them.)
https://pastebin.com/XhQEfhPb
The router identifies as ARM AFAICT:
https://pastebin.com/85Gz3RQu
Am I missing something? Is this something I need to install? I like the idea of running a journaled filesystem for more robust recovery from unclean/unexpected shutdowns.
Cheers,
-Taylorrr
Ah... that worked like a charm!
I'm seeing "extent" and "has_journal" when I grep "features" from tunefs -l /dev/sda1
Thanks,
-Taylorrr
