Hello,
I'm new to MoCA and Time Warner Cable, and I've tried to read as much as I can regarding MoCA before posting here.
I had TWC install a WH DVR system as part of a triple play package. I provided my own all-in-one cable modem/router (Netgear C3000), and they installed their Arris gateway and set it up so that it can only be used for my telephone service (Wi-Fi and Ethernet are disabled on it).
One thing everyone agrees on is installing a POE filter on the cable coming in to the house. I do not have one single cable coming in to my house. When my house was built, a cable outlet was installed in each room, and each cable meets in a home run in a plastic box mounted on the side of my house. TWC installed a powered amplifier/splitter (Antronix V900B) in the plastic box. I checked in the unlocked pedestal in my front yard and there is no POE filter there. I looked in the plastic box and there is no POE filter there either.
1) Should TWC have been responsible for installing a POE filter? Regardless, if I want to do it on my own, where should I install it? I don't think there's enough room in the box for me to install it.
When the TWC tech installed everything, he fed a cable in to my basement and connected that cable to a splitter (Commscope SV-2G) and connected the outputs to their Arris gateway and my Netgear cable modem. He said if I wanted to move the cable modem to a different room to improve, I can move the cable modem (and I *think* he said move the splitter with it) to anywhere else in the house. I decided to move it from the basement to the 2nd floor to improve wi-fi coverage where I need it. I moved the cable modem upstairs and I noticed almost immediately that our TV on the 1st floor started getting a poor signal from the cable box - the screen and audio froze quite a bit. When I connected the splitter in between the wall outlet and the cable modem, all of the TV issues cleared up.
2) Why on earth would putting a splitter in between the wall and modem in a room with no TV in it have any effect on my TV in a different room?
3) I'm considering getting an ActionTec MoCA Network adapter. I want to use it on an outlet with a cable box connected to it. I don't need the speeds provided with the bonded ECB6200, but as I do have a cable box connected on that outlet, am I better off spending the extra money for an ECB6200 so I can utilize the CATV passthru? Or will the ECB6000 and a splitter suffice?
4) I understand that if I want a MoCA to Ethernet adapter to work, I need to have more than one MoCA devices on my network. Can I assume that either the main DVR in my house and/or the extra cable box that I am able to play back recorded shows on will count as a MoCA devices so I'll only need to purchase 1 MoCA adapter?
5) When TWC installed everything, they used this Coax cable with a funky shield over each end of the coax cable attached to my cable modem (there's a "PPC" logo on it). Why?
