original-birdman
About two years ago I was having problems with my Entware installation on an RT-AC86U.
Files on the Entware distribution that started with "cr" (either case) were disappearing at 07:39 or 13:39.
This stopped gcc working....
I eventually tracked it down to asd.
I reported this to Asus, but heard nothing at all in response. But some time later it did stop happening.
I've now got an RT-BE92U and that has a similar problem, in that files are disappearing.
It now seems to be deleting all files/directories containing "zone", "link" or "pending" in their name. As well as deleting those starting with "cr" again.
Now, I know from the close thread https://www.snbforums.com/threads/what-is-asd-process.76242/ that this is an Asus issue, but what is teh best eway about getting this nonsense to stop?
Why is anything deleting entries by name rather than by content?
And why do I not have the option to switch this off?
Turns out it as also removing this, but I've only just noticed that in the log file I kept:1654907969[remove_file_in_dir]Delete harmful file,/tmp/opt/lib/gcc/aarch64-openwrt-linux-gnu/7.4.0/crt1.o
1654907969[blockfile] /tmp/opt/lib/gcc/aarch64-openwrt-linux-gnu/7.4.0/crt1.o is binary.
Odd that files are being tested by name, as that it hardly a marker for harmfullness.1654907972[remove_file_in_dir]Delete harmful directory,/tmp/opt/include/boost/regex/pending
1654907972[blockfile] dump unicode_iterator.hpp.
