more than 2 DNS servers ?
GoNz0
Is there any way to add more than 2 DNS servers on rMerlins firmware ?
had a quick look but it seems to search for the word server instead of both :confused:
Any reason why you need more? It's usually a bad idea, because if you have two malfunctioning DNS servers, then name resolution would be quite slow anyway if you need to try three different servers to properly resolve your queries.
if it is a bad idea I shall leave it alone :)
my netgear allows 3, i like my isp, google and openDNS you see.
Netgear's just an AP now.
