I have most of questions about Qos:
1. How to do L7 filter? eg, I like to make youtbue video as "HIGH" and skype as "HIGH", but block BT, emule, and they use random ports
2. Does Qos run in the list order. For example, first rule: port 9999 as high, second rule: any port > 1024 as low. The port 9998 is lowest, but what's about port 9999? (I ask because the order is important in TomatoUSB)
3. How to set up Qos rule with source ports instead of dst ports. eg, google voice use client port as tcp 19294
4. in nvram, I see 10 classification like tomato, how can I turn all 10 on instead of 5 currently.
other questions:
1. how to disable default router name, currently, it is named as "router.asus.com". I don't want any users to see what router I am using.
thanks!
other questions:
thanks!
