Mount a ext4 USB drive?
bmn1
I recently installed Merlin's ASUS WRT firmware, and wanted to install Skynet and Diversion.
The Skynet developer recommends ext4, and Diversion requires it.
Now, I can only get Skynet to recognize the USB drive and work with FAT32.
As soon as I pop in a ext4 drive, the router's WebGUI says it it's unmounted. And Skynet and Diversion do not detect it.
What am I missing here? Do I somehow mount it manually through the terminal?
Additional info:
RT-AC5300
Firmware Version: 384.8_2
Additional info:
RT-AC5300
Try this method. You may also need to set your USB port mode to 2.0 first (via Administration> System)
https://www.snbforums.com/threads/diversion-the-router-ad-blocker.48538/page-71#post-447604
Regarding USB 3.0 issue, you may read more here:
https://www.snbforums.com/threads/the-infamous-usb-3-0-issue-ok-on-stock-vs-not-ok-on-merlin.50333/
