Hello all,
Since i've changed my network topografy and put a firewall before my router/AP, I've decided to change configuration on my router and disable WAN port and move it to LAN side and be used as a fifth switch port and be used to connect directly to my firewall.
In this configuration, DHCP, DNS and firewall are disabled.
This is my default configuration with WAN port still active:
admin@Asus:/tmp/home/root# robocfg show
Switch: enabled
Port 0: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 1: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 00:0d:b9:47:19:9d
Port 2: 1000FD enabled stp: none vlan: 1 jumbo: off mac: d8:37:be:fd:f0:b8
Port 3: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 00:11:32:49:5c:47
Port 4: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 5: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 00:18:dd:41:07:06
Port 7: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 1c:b7:2c:c2:1d:00
Port 8: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
VLANs: BCM5301x enabled mac_check mac_hash
1: vlan1: 1 2 3 5 7t
The WAN port is configured in the same VLAN as all the ports (as expected) but WAN (port 0) are not configured in the switch, so I have no comms in this port.
Using some recommendation in several posts, I've executed the following command:
robocfg vlan ports "0 1 2 3 5 7t"
The result are:
Switch: enabled
Port 2: 1000FD enabled stp: none vlan: 1 jumbo: off mac: c4:6e:1f:3a:ce:3a
Port 3: 1000FD enabled stp: none vlan: 1 jumbo: off mac: b8:27:eb:1a:db:de
1: vlan1: 0 1 2 3 5t 7t
As expected, WAN (port 0) are in the switch but port 5 are automatically tagged on the VLAN and after that, LAN4 (port 4) and WiFi 5Ghz network stops connection to VLAN 1 despite that the command does not tag switch port 5.
How can I configure swith to put all ports, including WiFi to be on VLAN 1?
Thank you
Switch: enabled
The result are:
Switch: enabled
Thank you
