Multiple disks with a single volume without RAID
EscapeYourMind
Hello,
Is it possible to have a single logical volume that spans multiple disks without using RAID or JBOD?
I have a Synology DS414 for my home network and I don't really need, or even want to use, RAID. I do not need the redundancy it provides since I am ok with my data being inaccessible if things go wrong. I plan on having a backup strategy (May have questions about this at a future date, but my original plan is to have a 2nd DS414 and Time Backup to it) to restore my data. My other reasons for not wanting to use RAID are because I want to maximize space and don't want a drive failure to potentially cause a loss of everything on the primary DS414 (array rebuild causing another drive failure).
However, the one thing I do want is for everything to appear as a single volume to devices that access the NAS. I have media directories that contain more than a single disk can hold and I don't want to have to manage multiple directories across multiple disks. Which leads back to my question: Can I have a single volume span multiple disks without RAID?
Thanks!
Hello,
Thanks!
yes, but not advised.
So realistically my only option for presenting all of my media as a single volume, instead of multiples like Movies1, Movies2, Movies3, etc would be to use RAID?
As far as not losing storage availability, you can use Raid 0, also referred to as a striped raid. All storage available I'm pretty sure, but stevech has more experience with it. Steve, you can run Raid 0 on more than 2 discs, right?
i won't argue your reasoning on not wanting a parity drive taking up storage, but, in a 4 bay drive you can still have at least 9 TB available (Raid 5 x 4 discs, 1 disk for data protection). If you have a backup solution you're covered.
Yes you can raid 0 more than 2 drives. I know raid 0 would provide all available storage, but it has the problem of taking down the whole array if a drive dies, similar to JBOD I believe. What I was after was having the benefit of multiple disks appearing as a single logical volume, but if a disk or 2 or 3 dies, I would still be able to have full access to the other drives.
However it is looking like that isn't easily possible, and doesn't appear to be possible at all within a synology NAS. I guess I just need to make the decision between individual disks with increased file management, and just going with raid 5 and sacrificing some space for a single volume management.
Synology hybrid RAID would use multiple drives. I chose not to do that because of backup issues and I have only a 2 drive NAS. So the second drive is kept as a separate volume, not RAID1, so that I have protection on the 2nd volume as backup. For drive failure, file system corruption (which is why I don't like JBOD), human error (delete oops).
It looks like I am currently doing it the same way, and for the same reasons. I only have 2 drives in my DS414 right now. They are setup as individual volumes and time backup from one to the other. I have been trying to plan for when I get the other 2 drives which sort of prompted this thread.
It looks like once I get fully setup with a 2nd DS414 for backup, I will just use synology's hybrid raid on both of them and use time backup between them to cover myself in case the primary array goes down.
