Multiple OPVN clients issue?
lhurt5
I have several OVPN clients set up (Merlin 386.2.6). One client is set to "ON" and the other two are set to "OFF". The "ON" OVPN client routes all traffic through the tunnel with Policy Rules and blocks routed clients if the tunnel goes down.
I have noticed that if any of the "OFF" clients has the option to "block routed clients if the tunnel goes down" set to on, it will block all traffic from going through the only "ON" client, Is this a bug or is it by design? It does add extra steps when switching back and forth between VPN clients.
Unlike the other OpenVPN options, the "Block routed clients..." option is persistent, even when the OpenVPN client is turned OFF. And it's by design.
