EdCaffreyMS
I spent some time searching, but wasn't able to find any answers. Likely not typing in good search parameters..... So....
Years ago, when I built my home network, I used AC68U routers. As in THREE of them throughout the network...in order to supply sufficient wifi around the property/buildings. One is the "main" router connected directly to the ISP/modem, and the other two are connected to that main router via the LAN ports. A that time, my research showed that I SHOULD NOT have the same SSIDs/credentials on each router within the network (meaning I currently have 6 different SSIDs... three 2.4 and three 5.0)
Fast forward to today....
Was researching hardware to update/upgrade my network..... and I stumbled across a couple of articles stating that with multiple routers within the same network, is recommended to use the same SSID names/credentials for all the wifi on the same network...and that devices would "seamlessly" connect to different wifi routers based on signal strength. (sounded a lot like mesh networking, but that wasn't what was being referred to, and is something that I don't think I'm interested in)
Since that is completely opposite of my research years ago..... and how I have SSIDs/credentials setup on my current network..... what's the "proper" way of doing this? Should all three of the 2.4 networks be named and credentialed the same, and likewise with the 5.0? AND... would it work as a seamless network, which seemed to be implied in the reading I did?? It could also be a ton or work, as there are a number of wireless security cams on the various wifi networks that would require resetting/reinstalling. But.... it might be worth if I am updating the entire network with new hardware throughout.
Thoughts? Many Thanks in advance!
