Multiple Simultaneous VPN Clients Same VPN Provider
CaptainSTX
Part of the Furniture
While some VPN providers will only allow you to run a single VPN client on your router at any one time PIA has added a nice feature to their web site which makes it simple to run multiple clients.
While PIA's standard OVPN files work on Port 1198, UDP, AES-128-CBC, PIA has added, or at least it is the first time I have seen it, a custom configuration tool which will generate and download an OVPN file that will run on other ports with the applicable options needed for that port and the VPN server you want to use.
All that is required is that you upload the ovpn file into your VPN client, add your user name and password, apply the settings then start the client.
I've done some poking around PIA's site and I can't find the configuration tool. Do you have a link by any chance?
