Multiple users on openvpn
tweakertje
Hi all,
I use openvpn server on my ax88u and is it possible to connect multiple users on a single server? in my case there's only one possible.
If i connect the second one it gets the same ipadress eg 10.31.0.2
Try adding the following to the custom config field of the OpenVPN server.
username-as-common-name
P.S. I assume you're using username/passwords. And by multiple users, do you mean users using different usernames, or the same user w/ the same username making multiple connections?
