[possibly] easy question in answer, but i can't see how it can be done through the gui anyway.
is there anyway to have the default wireless networks:
ssid_2.4 GHz (WPA2 Personal)
ssid_5.0 GHz (WPA2 Personal)
and then add a second set of wireless networks with WEP only:
guest_ssid_2.4 GHz (WEP)
guest_ssid_5.0 GHz (WEP)
Reason is because apparently there may be issues with the PS Vita/PS4 Remote Play because I have spaces and symbols in my SSID. I'm not sure if this really is the issue, but I would like to test it, by setting up separate wireless networks on perhaps different bridge interfaces (for logging purposes) and a different set of iptables rules.
Can this be done?
Can this be done?
