My ISP is Wireless. How can I setup a home network?
technohindu
I just moved to an apartment building that provides free wireless internet throughout. It's a great connections too. However in my previous diggs I had a home network setup with both wired and wireless computers and also a media center pc which streamed content from other PCs in the house.
Now since the apartment building provides free internet each PC is connecting directly to the internet but not to each other. How do I adapt my home networking routers to receive the WAN connection wirelessly instead of through a cable modem?
I would in effect like to setup my own wireless LAN inside of the larger building LAN. Any ideas?
Thanks!
thiggins
Mr. Easy
Staff member
If you already have a wireless router, just use a wireless bridge like the Linksys WET610N or WGA600N and connect it to your router's WAN port.
zjohnr
You didn't provide any other info about other factors which may (or may not ... I'm still very inexperienced) affect how your wireless LAN performs.
  • What protocol does the apartment's wireless LAN use? (802.11g or something else?)
  • Is the apartment's wireless protocol the same as what you'd use on your local wireless LAN?
  • How much "stuff" would you be connecting? And would they all use the same wireless protocol or different?
Assuming the apartment uses 802.11g and so does all your stuff, then I'm not sure what channels you'd use for the bridge versus your wireless LAN other than to guess you'd want as much separation between them as possible. (Just a guess though ...)
-irrational john
technohindu
Bridge
Thanks for the replies. I currently have a belkin router and I also used a bridge to connect the wired and wireless parts of my prior setup. Belkin seemed to document that only their wireless bridges would work with their routers. I'm not sure if this was just a marketing ploy or true. I will give a linksys bridge a try.
To answer the other questions: The apartment is 802.11G and so is my home network.
Thanks for the help.
Hemanth
thiggins
Mr. Easy
Staff member
Probably marketing at work. As long as the Belkin bridge doesn't require WDS, it should work. What's the model #.
And as zjohnr noted, set your WLAN to use a different channel than your wireless "ISP" connection, choosing from 1, 6 or 11.
