my rt-ac66r have reboot problem
[email protected]
I bought asus rt-ac66r from newegg
it is refurbish so i can't replace other ac66r
because my ac66r have serious problem
it is reboot may be 26 second
AC66R Is not used for a long time, will be able to use the power is turned on
BUT After a while, and can not be used while still reboot
One month I tried to solve this problem
Finally gave up and came here to ask for help
1. I did use all kinds of firmware
2. Now the latest merlin firmware being used (3.0.0.4.374.34)
3. power on, 192.168.1.1 type use manager menu
4. Temperature is 2.4 GHz: 52°C - 5 GHz: 57°C
5. i can use all function ac66r but may be 15minutes later my ac66r reboot!! (all led bright, and reboot)
6. reboot later i can't use anything
7. i try contace asus support team but i can't solve this problem
and can't repair and replace because my ac66r referbish warrenty ended
but I don't use it one day TT
anybody can solve this problem?
Can you see anything funny in the log? One thing, can you switch AC adapter between two routers? Ever cleared NVRAM? Your English is bit difficult to understand, sorry.
By any chance if you are Korean, send PM to me in Korean.
