My Tempest Weather Station -Offline Need some Help please
Wayne Hutchinson
Starting yesterday just after midnight My Tempest Weather Station can longer be authorized on my AXE 16000. I have rebooted router and yesterday and after a couple reboots it did manage to be authorized.
Same thing occurred this morning.
I have had Tempest online for a number years and have not had any issues like this on any router
Thanks for any help in diagnosing this problem
It gets an IP but immediately is deauthorized. I
I am on latest version of ASUSWRT and Skynet. Not sure if the Tempest hub is failing or if this something with router.
This is system log showing issue:
Jan 13 05:01:43 wlceventd: wlceventd_proc_event(645): eth10: Deauth_ind B0:38:29:9C:FB:AD, status: 0, reason: Unspecified reason (1), rssi:-34
Jan 13 05:01:43 wlceventd: wlceventd_proc_event(685): eth10: Auth B0:38:29:9C:FB:AD, status: Successful (0), rssi:-34
Jan 13 05:01:43 wlceventd: wlceventd_proc_event(695): eth10: ReAssoc B0:38:29:9C:FB:AD, status: Successful (0), rssi:-34
Jan 13 05:01:43 wlceventd: wlceventd_proc_event(645): eth10: Deauth_ind D0:EF:76:2A:02:D8, status: 0, reason: Unspecified reason (1), rssi:-45
Jan 13 05:01:43 wlceventd: wlceventd_proc_event(685): eth10: Auth D0:EF:76:2A:02:D8, status: Successful (0), rssi:-45
Jan 13 05:01:45 wlceventd: wlceventd_proc_event(645): eth10: Deauth_ind B0:38:29:9C:FB:AD, status: 0, reason: Unspecified reason (1), rssi:-34
Jan 13 05:01:45 wlceventd: wlceventd_proc_event(685): eth10: Auth B0:38:29:9C:FB:AD, status: Successful (0), rssi:-34
Jan 13 05:01:45 wlceventd: wlceventd_proc_event(695): eth10: ReAssoc B0:38:29:9C:FB:AD, status: Successful (0), rssi:-34
Jan 13 05:01:46 wlceventd: wlceventd_proc_event(645): eth10: Deauth_ind B8:27:EB:4A:18:9B, status: 0, reason:
Should also include I am on the latest Asuswrt and running Skynet
Asuswrt (i.e. stock firmware) doesn't support scripts like Skynet, so I'm assuming you're using asuswrt-merlin.
Try disabling custom scripts in the webUI and rebooting the router. If your device can then connect it's an indication of a script problem.
Can you explain "disabling custom scripts webui" Yes, I am on asuswrt-merlin and have Skynet running, only no extras.
