My third RT-AC66U and still issues.
oni222
First off let me say great job to Merlin. Thank you for all the work you have put into this project.
Now for my problem. This is the third RT-AC66U I have purchased and I have had the same issue with each router. I get really slow speeds on all my devices.
I have the Asus gigabit wireless card (PCE-AC66) on my desktop, I also have two killer bigfoot 1103 (450mbps) wifi cards on my two laptops.
I get a 450mbps connection on my laptops and 800~ mbps on my desktop but when I try to either stream a video file from my NAS box or copy a file I get 10-100kb/s. Yes I said KB!
When I connect all the devices using the ethernet cable all the transfer rates are fine. Also when I use my crappy 20 dollar router wifi works fine albeit at 54mbps :P
I tried both 5gz and 2.4ghz and I get the same results. 2.4 is at channel 11 and 5ghz is 36.
I will also add a second post with my log information so feel free to skip reading it if you do not need it.
Thanks in advance for any help I can get. I really hope to get this router to work. It really is a great router and I hoped that a firmware would fix all its issues but at this point I have paid allot of money for an expensive paper weight :(
Dec 31 19:00:09 syslogd started: BusyBox v1.20.2
Dec 31 19:00:09 syslog: module ledtrig-usbdev not found in modules.dep
Dec 31 19:00:09 syslog: module leds-usb not found in modules.dep
Dec 31 19:00:09 kernel: Built 1 zonelists. Total pages: 585216
Dec 31 19:00:09 kernel: Kernel command line: root=/dev/mtdblock3 console=ttyS0,115200 init=/sbin/preinit
Dec 31 19:00:09 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Dec 31 19:00:09 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Dec 31 19:00:09 kernel: Synthesized TLB refill handler (20 instructions).
Dec 31 19:00:09 kernel: Synthesized TLB load handler fastpath (32 instructions).
Dec 31 19:00:09 kernel: Synthesized TLB store handler fastpath (32 instructions).
Dec 31 19:00:09 kernel: Synthesized TLB modify handler fastpath (31 instructions).
Dec 31 19:00:09 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Dec 31 19:00:09 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Dec 31 19:00:09 kernel: Using 300.000 MHz high precision timer.
Dec 31 19:00:09 kernel: console [ttyS0] enabled
Dec 31 19:00:09 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 31 19:00:09 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 31 19:00:09 kernel: Memory: 238608k/131068k available (2529k kernel code, 22576k reserved, 510k data, 196k init, 131072k highmem)
Dec 31 19:00:09 kernel: Mount-cache hash table entries: 512
Dec 31 19:00:09 kernel: NET: Registered protocol family 16
Dec 31 19:00:09 kernel: PCI: Initializing host
Dec 31 19:00:09 kernel: PCI: Reset RC
Dec 31 19:00:09 kernel: PCI: Fixing up bus 0
Dec 31 19:00:09 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Dec 31 19:00:09 kernel: PCI: Fixing up bridge
Dec 31 19:00:09 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Dec 31 19:00:09 kernel: PCI: Fixing up bus 1
Dec 31 19:00:09 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Dec 31 19:00:09 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Dec 31 19:00:09 kernel: PCI: Fixing up bus 2
Dec 31 19:00:09 kernel: NET: Registered protocol family 2
Dec 31 19:00:09 kernel: Time: MIPS clocksource has been installed.
Dec 31 19:00:09 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Dec 31 19:00:09 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Dec 31 19:00:09 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Dec 31 19:00:09 kernel: TCP: Hash tables configured (established 16384 bind 16384)
Dec 31 19:00:09 kernel: TCP reno registered
Dec 31 19:00:09 kernel: highmem bounce pool size: 64 pages
Dec 31 19:00:09 kernel: squashfs: version 3.2-r2 (2007/01/15) Phillip Lougher
Dec 31 19:00:09 kernel: io scheduler noop registered (default)
Dec 31 19:00:09 kernel: HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
Dec 31 19:00:09 kernel: N_HDLC line discipline registered.
Dec 31 19:00:09 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
Dec 31 19:00:09 kernel: serial8250: ttyS0 at MMIO 0x0 (irq = 8) is a 16550A
Dec 31 19:00:09 kernel: serial8250: ttyS1 at MMIO 0x0 (irq = 8) is a 16550A
Dec 31 19:00:09 kernel: PPP generic driver version 2.4.2
Dec 31 19:00:09 kernel: MPPE/MPPC encryption/compression module registered
Dec 31 19:00:09 kernel: NET: Registered protocol family 24
Dec 31 19:00:09 kernel: PPPoL2TP kernel driver, V0.18.3
Dec 31 19:00:09 kernel: PPTP driver version 0.8.5
Dec 31 19:00:09 kernel: pflash: found no supported devices
Dec 31 19:00:09 kernel: Boot partition size = 262144(0x40000)
Dec 31 19:00:09 kernel: Creating 2 MTD partitions on "sflash":
Dec 31 19:00:09 kernel: 0x00000000-0x00040000 : "pmon"
Dec 31 19:00:09 kernel: 0x001f0000-0x00200000 : "nvram"
Dec 31 19:00:09 kernel: Found a Zentel NAND flash with 2048B pages or 128KB blocks; total size 128MB
Dec 31 19:00:09 kernel: lookup_nflash_rootfs_offset: offset = 0x0
Dec 31 19:00:09 kernel: nflash: squash filesystem with lzma found at block 9
Dec 31 19:00:09 kernel: Creating 2 MTD partitions on "nflash":
Dec 31 19:00:09 kernel: 0x00000000-0x02000000 : "linux"
Dec 31 19:00:09 kernel: 0x001312c0-0x02000000 : "rootfs"
Dec 31 19:00:09 kernel: NAND device: Manufacturer ID: 0x92, Chip ID: 0xf1 (Zentel NAND 128MiB 3,3V 8-bit)
Dec 31 19:00:09 kernel: Creating 3 MTD partitions on "brcmnand":
Dec 31 19:00:09 kernel: 0x00000000-0x02000000 : "trx"
Dec 31 19:00:09 kernel: 0x02000000-0x04000000 : "jffs2"
Dec 31 19:00:09 kernel: 0x04000000-0x07f00000 : "brcmnand"
Dec 31 19:00:09 kernel: dev_nvram_init: _nvram_init
Dec 31 19:00:09 kernel: _nvram_init: allocat size= 65536
Dec 31 19:00:09 kernel: sdhci: Secure Digital Host Controller Interface driver
Dec 31 19:00:09 kernel: sdhci: Copyright(c) Pierre Ossman
Dec 31 19:00:09 kernel: u32 classifier
Dec 31 19:00:09 kernel: OLD policer on
Dec 31 19:00:09 kernel: Netfilter messages via NETLINK v0.30.
Dec 31 19:00:09 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Dec 31 19:00:09 kernel: ipt_time loading
Dec 31 19:00:09 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 19:00:09 kernel: net/ipv4/netfilter/tomato_ct.c [Mar 3 2013 13:46:24]
Dec 31 19:00:09 kernel: ipt_account 0.1.21 : Piotr Gasidlo <[email protected]>, http://code.google.com/p/ipt-account/
Dec 31 19:00:09 kernel: NET: Registered protocol family 10
Dec 31 19:00:09 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 19:00:09 kernel: NET: Registered protocol family 17
Dec 31 19:00:10 kernel: 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
Dec 31 19:00:10 kernel: All bugs added by David S. Miller <[email protected]>
Dec 31 19:00:10 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Dec 31 19:00:10 kernel: Freeing unused kernel memory: 196k freed
Dec 31 19:00:10 kernel: Warning: unable to open an initial console.
Dec 31 19:00:10 kernel: Failed to execute /sbin/preinit. Attempting defaults...
Dec 31 19:00:10 kernel: ctf: module license 'Proprietary' taints kernel.
Dec 31 19:00:10 kernel: et_module_init: passivemode set to 0x0
Dec 31 19:00:10 kernel: et_module_init: et_txq_thresh set to 0x400
Dec 31 19:00:10 kernel: bcm_robo_enable_switch: EEE is disabled
Dec 31 19:00:10 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.39.31 (r341183)
Dec 31 19:00:10 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Dec 31 19:00:10 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.39.31 (r341183)
Dec 31 19:00:10 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Dec 31 19:00:10 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.39.31 (r341183)
Dec 31 19:00:10 kernel: Algorithmics/MIPS FPU Emulator v1.5
Dec 31 19:00:10 kernel: usbcore: registered new interface driver usbfs
Dec 31 19:00:10 kernel: usbcore: registered new interface driver hub
Dec 31 19:00:10 kernel: usbcore: registered new device driver usb
Dec 31 19:00:10 kernel: SCSI subsystem initialized
Dec 31 19:00:10 kernel: Initializing USB Mass Storage driver...
Dec 31 19:00:10 kernel: usbcore: registered new interface driver usb-storage
Dec 31 19:00:10 kernel: USB Mass Storage support registered.
Dec 31 19:00:10 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c0211000
Dec 31 19:00:10 kernel: NTFS (with native replay) support included
Dec 31 19:00:10 kernel: optimized: speed
Dec 31 19:00:10 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Dec 31 19:00:10 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec 31 19:00:10 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
Dec 31 19:00:10 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
Dec 31 19:00:10 kernel: ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
Dec 31 19:00:10 kernel: ehci_hcd 0000:00:04.1: irq 6, io mem 0x18004000
Dec 31 19:00:10 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
Dec 31 19:00:10 kernel: usb usb1: configuration #1 chosen from 1 choice
Dec 31 19:00:10 kernel: hub 1-0:1.0: USB hub found
Dec 31 19:00:10 kernel: hub 1-0:1.0: 2 ports detected
Dec 31 19:00:10 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec 31 19:00:10 kernel: ohci_hcd 0000:00:04.0: OHCI Host Controller
Dec 31 19:00:10 kernel: ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
Dec 31 19:00:10 kernel: ohci_hcd 0000:00:04.0: irq 6, io mem 0x18009000
Dec 31 19:00:10 kernel: usb usb2: configuration #1 chosen from 1 choice
Dec 31 19:00:10 kernel: hub 2-0:1.0: USB hub found
Dec 31 19:00:10 kernel: hub 2-0:1.0: 2 ports detected
Dec 31 19:00:10 kernel: usbcore: registered new interface driver usblp
Dec 31 19:00:10 kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Dec 31 19:00:10 kernel: usb 1-1: new high speed USB device using ehci_hcd and address 2
Dec 31 19:00:10 kernel: usb 1-1: configuration #1 chosen from 1 choice
Dec 31 19:00:10 kernel: hub 1-1:1.0: USB hub found
Dec 31 19:00:10 kernel: hub 1-1:1.0: 4 ports detected
Dec 31 19:00:10 kernel: usbcore: registered new interface driver asix
Dec 31 19:00:10 kernel: usbcore: registered new interface driver cdc_ether
Dec 31 19:00:10 kernel: usbcore: registered new interface driver net1080
Dec 31 19:00:10 kernel: usbcore: registered new interface driver rndis_host
Dec 31 19:00:10 kernel: usbcore: registered new interface driver zaurus
Dec 31 19:00:10 kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Dec 31 19:00:10 kernel: ADDRCONF(NETDEV_UP): eth1: link is not ready
Dec 31 19:00:10 kernel: ADDRCONF(NETDEV_UP): eth2: link is not ready
Dec 31 19:00:10 kernel: br0: starting userspace STP failed, staring kernel STP
Dec 31 19:00:10 kernel: vlan1: dev_set_promiscuity(master, 1)
Dec 31 19:00:10 kernel: device eth0 entered promiscuous mode
Dec 31 19:00:10 kernel: device vlan1 entered promiscuous mode
Dec 31 19:00:11 kernel: device eth1 entered promiscuous mode
Dec 31 19:00:11 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Dec 31 19:00:12 kernel: device eth2 entered promiscuous mode
Dec 31 19:00:12 kernel: device wl0.1 entered promiscuous mode
Dec 31 19:00:12 kernel: br0: port 4(wl0.1) entering listening state
Dec 31 19:00:12 kernel: br0: port 3(eth2) entering listening state
Dec 31 19:00:12 kernel: br0: port 2(eth1) entering listening state
Dec 31 19:00:12 kernel: br0: port 1(vlan1) entering listening state
Dec 31 19:00:12 kernel: br0: port 4(wl0.1) entering learning state
Dec 31 19:00:12 kernel: br0: port 3(eth2) entering learning state
Dec 31 19:00:12 kernel: br0: port 2(eth1) entering learning state
Dec 31 19:00:12 stop_nat_rules: apply the redirect_rules!
Dec 31 19:00:12 kernel: br0: port 1(vlan1) entering learning state
Dec 31 19:00:12 kernel: br0: topology change detected, propagating
Dec 31 19:00:12 kernel: br0: port 4(wl0.1) entering forwarding state
Dec 31 19:00:12 kernel: br0: port 3(eth2) entering forwarding state
Dec 31 19:00:12 kernel: br0: port 2(eth1) entering forwarding state
Dec 31 19:00:12 WAN Connection: ISP's DHCP did not function properly.
Dec 31 19:00:13 kernel: br0: port 1(vlan1) entering forwarding state
Dec 31 19:00:13 notify_rc : start_nat_rules
Dec 31 19:00:13 kernel: nf_conntrack_rtsp v0.6.21 loading
Dec 31 19:00:13 kernel: nf_nat_rtsp v0.6.21 loading
Dec 31 19:00:14 notify_rc : stop_upnp
Dec 31 19:00:14 rc_service: stop_upnp is waitting start_nat_rules...
Dec 31 19:00:14 notify_rc : start_radvd
Dec 31 19:00:14 rc_service: start_radvd is waitting start_nat_rules...
Dec 31 19:00:15 WAN Connection: WAN was restored.
Dec 31 19:00:15 notify_rc : start_nat_rules
Dec 31 19:00:15 rc_service: start_nat_rules is waitting start_nat_rules...
Dec 31 19:00:18 dnsmasq[578]: started, version 2.65 cachesize 1500
Dec 31 19:00:18 dnsmasq[578]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack
Dec 31 19:00:18 dnsmasq[578]: asynchronous logging enabled, queue limit is 5 messages
Dec 31 19:00:18 dnsmasq-dhcp[578]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Dec 31 19:00:18 dnsmasq[578]: read /etc/hosts - 4 addresses
Dec 31 19:00:18 dnsmasq-dhcp[578]: read /etc/ethers - 3 addresses
Dec 31 19:00:18 dnsmasq[578]: using nameserver 75.75.76.76#53
Dec 31 19:00:18 dnsmasq[578]: using nameserver 75.75.75.75#53
Dec 31 19:00:18 RT-AC66U: start httpd
Dec 31 19:00:18 crond[581]: crond: crond (busybox 1.20.2) started, log level 8
Dec 31 19:00:19 pptpd[599]: MGR: Config file not found!
Dec 31 19:00:19 pptpd[599]: MGR: Maximum of 100 connections reduced to 10, not enough IP addresses given
Dec 31 19:00:19 pptpd[599]: accel-pptpd-0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Dec 31 19:00:19 pptpd[603]: MGR: Manager process started
Dec 31 19:00:19 pptpd[603]: MGR: Maximum of 10 connections available
Dec 31 19:00:19 miniupnpd[601]: HTTP listening on port 60270
Dec 31 19:00:19 miniupnpd[601]: Listening for NAT-PMP traffic on port 5351
Dec 31 19:00:19 bcrelay[604]: Running as child
Dec 31 19:00:19 Samba Server: daemon is started
Dec 31 19:00:19 disk monitor: be idle
Dec 31 19:00:20 nmbd[619]: [2010/12/31 19:00:20, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Dec 31 19:00:20 nmbd[619]: Samba server RT-AC66U is now a domain master browser for workgroup WORKGROUP on subnet UNICAST_SUBNET
Dec 31 19:00:20 kernel: Ebtables v2.0 registered
Dec 31 19:00:21 start_nat_rules: apply the nat_rules!
Dec 31 19:00:21 notify_rc : start_httpd
Dec 31 19:00:21 rc_service: start_httpd is waitting start_radvd...
Dec 31 19:00:21 radvd[653]: version 1.9.1 started
Dec 31 19:00:22 notify_rc : start_upnp
Dec 31 19:00:22 rc_service: start_upnp is waitting stop_upnp...
Dec 31 19:00:22 RT-AC66U: start httpd
Dec 31 19:00:22 dnsmasq-dhcp[578]: DHCPREQUEST(br0) 192.168.1.3 00:08:9b:ca:e2:ea
Dec 31 19:00:22 dnsmasq-dhcp[578]: DHCPACK(br0) 192.168.1.3 00:08:9b:ca:e2:ea ONI
Dec 31 19:00:23 kernel: protocol 0000 is buggy, dev eth0
Dec 31 19:00:23 miniupnpd[662]: HTTP listening on port 57698
Dec 31 19:00:23 miniupnpd[662]: Listening for NAT-PMP traffic on port 5351
Dec 31 19:00:23 ddns: clear ddns cache file for server setting change
Dec 31 19:00:23 ddns update: connected to members.dyndns.org (204.13.248.111) on port 80.
Dec 31 19:00:23 ddns update: server output: HTTP/1.1 200 OK^M Date: Wed, 13 Mar 2013 01:24:10 GMT^M Server: Apache^M Content-Type: text/plain^M Accept-Ranges: none^M Connection: close^M ^M badauth
Dec 31 19:00:23 ddns update: authentication failure
Dec 31 19:00:23 notify_rc : stop_ntpc
Dec 31 19:00:23 notify_rc : start_ntpc
Dec 31 19:00:23 rc_service: start_ntpc is waitting stop_ntpc...
Dec 31 19:00:24 dhcp client: bound 50.154.185.92 via 50.154.185.1 during 253078 seconds.
Mar 12 21:24:11 notify_rc : restart_upnp
Mar 12 21:24:11 notify_rc : restart_radvd
Mar 12 21:24:11 notify_rc : restart_diskmon
Mar 12 21:24:11 rc_service: restart_diskmon is waitting restart_radvd...
Mar 12 21:24:11 radvd[658]: Exiting, sigterm or sigint received.
Mar 12 21:24:11 radvd[658]: sending stop adverts
Mar 12 21:24:11 radvd[658]: removing /var/run/radvd.pid
Mar 12 21:24:11 radvd[679]: version 1.9.1 started
Mar 12 21:24:11 miniupnpd[674]: HTTP listening on port 37072
Mar 12 21:24:11 miniupnpd[674]: Listening for NAT-PMP traffic on port 5351
Mar 12 21:24:11 disk monitor: be idle
Mar 12 21:24:12 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:24:15 kernel: printk: 43 messages suppressed.
Mar 12 21:24:15 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:24:16 nmbd[619]: [2013/03/12 21:24:16, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Mar 12 21:24:16 nmbd[619]: Samba server RT-AC66U is now a domain master browser for workgroup WORKGROUP on subnet 192.168.1.1
Mar 12 21:24:20 kernel: printk: 71 messages suppressed.
Mar 12 21:24:20 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:24:25 kernel: printk: 55 messages suppressed.
Mar 12 21:24:25 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:24:26 dnsmasq-dhcp[578]: DHCPREQUEST(br0) 192.168.1.6 cc:52:af:5a:03:ee
Mar 12 21:24:26 dnsmasq-dhcp[578]: DHCPACK(br0) 192.168.1.6 cc:52:af:5a:03:ee Klio-HP
Mar 12 21:24:29 nmbd[619]: [2013/03/12 21:24:29, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Mar 12 21:24:29 nmbd[619]: Samba name server RT-AC66U is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.1
Mar 12 21:24:30 kernel: printk: 345 messages suppressed.
Mar 12 21:24:30 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:24:35 kernel: printk: 340 messages suppressed.
Mar 12 21:24:35 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:24:40 kernel: printk: 335 messages suppressed.
Mar 12 21:24:40 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:24:41 dnsmasq-dhcp[578]: DHCPREQUEST(br0) 192.168.1.12 5c:95:ae:65:be:4b
Mar 12 21:24:41 dnsmasq-dhcp[578]: DHCPACK(br0) 192.168.1.12 5c:95:ae:65:be:4b Elenis-iPhone-4
Mar 12 21:24:45 kernel: printk: 251 messages suppressed.
Mar 12 21:24:45 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:24:48 crond[581]: time disparity of 1154964 minutes detected
Mar 12 21:24:50 kernel: printk: 442 messages suppressed.
Mar 12 21:24:50 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:24:52 dnsmasq-dhcp[578]: DHCPREQUEST(br0) 192.168.1.4 60:a4:4c:82:9f:4a
Mar 12 21:24:52 dnsmasq-dhcp[578]: DHCPACK(br0) 192.168.1.4 60:a4:4c:82:9f:4a Gaming-Desktop
Mar 12 21:24:55 kernel: printk: 649 messages suppressed.
Mar 12 21:24:55 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:00 kernel: printk: 345 messages suppressed.
Mar 12 21:25:00 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:05 kernel: printk: 359 messages suppressed.
Mar 12 21:25:05 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:10 kernel: printk: 336 messages suppressed.
Mar 12 21:25:10 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:15 kernel: printk: 1180 messages suppressed.
Mar 12 21:25:15 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:20 kernel: printk: 1228 messages suppressed.
Mar 12 21:25:20 kernel: Neighbour table overflow.
Mar 12 21:25:25 kernel: printk: 1527 messages suppressed.
Mar 12 21:25:25 kernel: Neighbour table overflow.
Mar 12 21:25:30 kernel: printk: 1002 messages suppressed.
Mar 12 21:25:30 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:35 kernel: printk: 497 messages suppressed.
Mar 12 21:25:35 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:40 kernel: printk: 545 messages suppressed.
Mar 12 21:25:40 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:45 kernel: printk: 668 messages suppressed.
Mar 12 21:25:45 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:50 kernel: printk: 1405 messages suppressed.
Mar 12 21:25:50 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:25:54 dnsmasq-dhcp[578]: DHCPREQUEST(br0) 192.168.1.14 44:d8:84:8a:86:ef
Mar 12 21:25:54 dnsmasq-dhcp[578]: DHCPACK(br0) 192.168.1.14 44:d8:84:8a:86:ef mye8840s-iPod
Mar 12 21:25:55 kernel: printk: 914 messages suppressed.
Mar 12 21:25:55 kernel: Neighbour table overflow.
Mar 12 21:26:00 kernel: printk: 647 messages suppressed.
Mar 12 21:26:00 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:26:03 dnsmasq-dhcp[578]: DHCPDISCOVER(br0) 44:d8:84:8a:86:ef
Mar 12 21:26:03 dnsmasq-dhcp[578]: DHCPOFFER(br0) 192.168.1.14 44:d8:84:8a:86:ef
Mar 12 21:26:05 kernel: printk: 450 messages suppressed.
Mar 12 21:26:05 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:26:10 kernel: printk: 711 messages suppressed.
Mar 12 21:26:10 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:26:15 kernel: printk: 593 messages suppressed.
Mar 12 21:26:15 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:26:20 kernel: printk: 310 messages suppressed.
Mar 12 21:26:20 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:26:21 dnsmasq-dhcp[578]: DHCPREQUEST(br0) 192.168.1.227 38:aa:3c:83:26:63
Mar 12 21:26:21 dnsmasq-dhcp[578]: DHCPACK(br0) 192.168.1.227 38:aa:3c:83:26:63 android-9182738ee2d05933
Mar 12 21:26:25 kernel: printk: 390 messages suppressed.
Mar 12 21:26:25 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:26:30 kernel: printk: 429 messages suppressed.
Mar 12 21:26:30 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:26:35 kernel: printk: 516 messages suppressed.
Mar 12 21:26:35 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:26:40 kernel: printk: 569 messages suppressed.
Mar 12 21:26:40 kernel: protocol 0000 is buggy, dev eth0
Mar 12 21:26:45 kernel: printk: 534 messages suppressed.
Mar 12 21:26:45 kernel: protocol 0000 is buggy, dev eth0
Have you tried transferring a file between both computers rather than from your NAS? Just to see if it makes any difference.
Make sure you have Jumbo Frames disabled on the NAS if you had it enabled - it might cause issues since wireless probably can't handle those large packets.
I doubt it's related to interference since it happens on both band. Doubt it's related to defective HW since you've tried more than one router.
if you go jumbo frames, you have to have everything with jumbo frames end-to-end or you get slowness. I wouldn't recommend using them for home use.
I have tried transferring files from my computers and the same result.
I will try disabling jumbo frames on all my devices. I am at work right now so I cannot try it for another hour or two.
hmm under jumbo frame for my NAS box, all I see are the following options:
1500
4074
7418
9000
It was under 1500 since that is the only option I recognized from my other devices aka ps3 etc.
I was also thinking.... Since my previous routers all worked fine with the current network setup then why is jumbo frame acting up now?
PS: Previous routers where e4200 fake cisco (worked at 450mbps no issues) current e1000 (works at 54 but i got it for 20 bucks).
So why when I connect on my laptops with 450mbps and desktop with 700-800 mbps do I get the super slow speeds?
EDIT:
So jumbo frames was disabled on my router, once I enabled it the transfer speeds increased to 600-900KB/s...... So that is like a 100% improvement but still EXTREMELY slow :( the file I transferred was 7gigs mkv.
I would start with the basics, as there is no reason why three different routers should exhibit such low speed. You need to simplify the network to its minimum, with as little configuration changes as possible to isolate the root cause.
1) Reset your router to factory defaults
2) Configure only your Internet access and the wireless. Use WPA2-Personal and AES security, leave it on Auto for now. Do not change any other settings.
3) Try with one single computer connected and the modem - no other device, wired or wireless. Do a speed test on Speedtest.net. Is the speed close to what your ISP is giving you?
4) If the speed is correct, add just your NAS, and try a file transfer. Try in both directions: from the NAS, and to the NAS.
5) Make sure that the cable between the NAS and the router is Cat5e or Cat6. If your old router only had 100 Mbits ports and you are using an older cable, that would explain why you are having issues with the new router.
I will try doing a factory reset like you said in your steps 1-4.
As for 5 all my routers where gigabit speed for the ethernet ports. All my cables are cat6 throughout the house. The speed is horrible for every device from the laptops, ps3, xbox and even the tablets.
If I hard wire the devices (laptops,desktop and ps3/xbox) they all work perfectly. The issue is with the wireless.
All three RT-AC66U routers had the same issue.
I will post back after I reset the router.
PS: Thank you for your help.
Ok so I did like you suggested. I reset the router to its default settings and I only setup my wireless network settings.
Everything else is default.
and.....
.... (I am a master of suspense!)
It worked! The desktop is getting 40-60mb/s and the laptop is doing 16mb/s.
I am curious now what setting screwed up the router.....
Thank you oh Mighty Wizard Merlin! <3
EDIT: I am going to try and find out what the culprit was because I have a few friends at work that have had the exact same issue as me with this router.
and.....
Did you find what was causing this?
