nand for r7800
Gallo
hiya peeps, anyone got any idea where I could order the flash for an r7800
micron MT29F1G08ABBEAH4:E
the router bit the dust and I got alot of free time so I was gonna try and salvage it.
thanx in advance
The NAND model seems to be EOL, you may try your luck on local electronic repair store first.
You could try search it on ailexpress, but there is chance you will get the counterfeit one, so beware.
Moreover, It's from china, so shipping is unpredictable.
Check these chips:
Micron:
MT29F1G08ABBEAH4 / MT29F1G08ABBEAH4:E
SkyHigh(Cypress/SK Hynix)/Cypress/AMD/Spansion:
S34MS01G2
Spansion/Cypress:
S34ML01G100TFI00
Macronix:
MX30UF1G18AC / MX30LF1G18AC / MX30LF1G18AC-TI
Other manufacturers:
Numonyx, Toshiba, Samsung, Esmt, Mxic, Zentel, Winbond
Good luck, and please report back!
thank you all for the responses, I'm calling mouser and digikey tomorrow, I had found their listing, although its out of stock. The router isn't a necessity but a fun project, if I find one great if I don't thats fine also
