NAS aggregation or virtualization?
iamnemo
My setup:
I have six (6) D-Link DNS-323 NAS (v1.07 firmware) and a XP Pro computer connected to an 8-port unmanaged gigabit switch which is itself connected (for internet access) to my router (WRT54G) which is the DHCP server for my network.
Everything works fine except for the "wake-up" problem mentioned below.
Now my question is:
I would like to see the six DNS-323 units as a single file system in XP Pro, i.e. one drive letter with each NAS as a folder under root. I believe this is known as NAS/file aggregation/virtualization.
What are my options for doing that (preferably software only). Thanks!
Wake-up problem:
Sometimes one of the DNS-323 doesn't "wake up" when accessed and I have to reboot it.
Thanks! Iam
iSCSI might do what you want, but the DNS-323 doesn't support that. At least not with factory firmware.
Sorry, but I don't know anything about the "wake up" problem.
Thank you Tim for your time. Somebody else also suggested iSCSI but, as you wrote, I need to install another firmware in my DNS-323. I might do that if nothing else works. Thanks again! Iam
My setup:
Now my question is:
Wake-up problem:
Thanks! Iam
Well you can do this using local disks in XP by setting a drive to map to a folder instead of a drive letter. For now I have not figured out if you can do it for network mapped shares. I do think it is possible without resorting to special software but I would have to do more research on how windows maps drives. For the time being you could create a local folder with links to your six different NASes that would act like what you are describing. It really depends on why you need things setup this way.
00Roush
