nat-start for policy-based PORT routing
pierredugland
Hello,
I have followed the instructions here : https://github.com/RMerl/asuswrt-merlin.ng/wiki/Policy-based-Port-routing-(manual-method)
Here is my nat-start
#!/bin/sh
sleep 10  # During the boot process nat-start may run multiple times so this is required
# Ensure duplicate rules are not created
for VPN_ID in 0 1 2 3 4 5
   do
      ip rule del prio 999$VPN_ID  2>/dev/null
   done
# Create the RPDB rules
ip rule add from 0/0 fwmark "0x8000/0x8000" table main   prio 9990        # WAN   fwmark
ip rule add from 0/0 fwmark "0x7000/0x7000" table ovpnc4 prio 9991        # VPN 4 fwmark
ip rule add from 0/0 fwmark "0x3000/0x3000" table ovpnc5 prio 9992        # VPN 5 fwmark
ip rule add from 0/0 fwmark "0x1000/0x1000" table ovpnc1 prio 9993        # VPN 1 fwmark
ip rule add from 0/0 fwmark "0x2000/0x2000" table ovpnc2 prio 9994        # VPN 2 fwmark
ip rule add from 0/0 fwmark "0x4000/0x4000" table ovpnc3 prio 9995        # VPN 3 fwmark
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 192.168.1.23 -p tcp -m multiport --dport 8112,8113 -j MARK --set-mark 0x2000/0x2000
I have verified that, when routing all traffic from 192.168.1.23 (using the UI), the vpn does work (i.e the traffic does get routed through the vpn client instance 2).
I have no other jffs scripts on the router. I have the latest (384_16) firmware version and restarted the router after modifying the script just in case.
What am I doing wrong ?
PS : this is p2p traffic so I'm checking the resulting IP by adding a magnet link in my deluge instance running into a docker container on my NAS. The NAS is 192.168.1.23 and the 8112 port on the nas gets forwarded to WAN port 8112 as well.
re-upping since I have still not found a solution. Is there a better place to ask questions ? SO maybe ?
Did you check the rules for hits?
e.g. Enter the following one-liner (redact your WAN IP from Table main before posting)
echo -e "\n\t"RPDB Rules;ip rule;echo;for I in 1 2 3 4 5;do [ -n "$(nvram get vpn_client${I}_addr)" ] && echo -e "\t"Client ovpnc$I port $(nvram get vpn_client${I}_port) $(nvram get vpn_client${I}_proto) || echo -e "\t"Client ovpnc${I} NOT configured;ip route show table 11$I |  grep -E "^0\.|^128.|^default|^prohibit|tun1";done;echo -e "\n\t"Table main;ip route show table 254 | grep -E "^0\.|^128.|^default"; echo -e "\n\n\tFWMARK Tagging";iptables -nvL PREROUTING -t mangle --line;echo -e "\n\n\tPort Forward";nvram get vts_rulelist
Thanks for taking the time:
   RPDB Rules
0:      from all lookup local
32766:  from all lookup main
32767:  from all lookup default
        Client ovpnc1 port 8443 tcp-client
        Client ovpnc2 port 8443 tcp-client
10.7.5.0/24 dev tun12  proto kernel  scope link  src 10.7.5.4
0.0.0.0/1 via 10.7.5.1 dev tun12
128.0.0.0/1 via 10.7.5.1 dev tun12
default via the_ip dev eth0
        Client ovpnc3 NOT configured
        Client ovpnc4 NOT configured
        Client ovpnc5 NOT configured
        Table main
        FWMARK Tagging
Chain PREROUTING (policy ACCEPT 3416K packets, 776M bytes)
num   pkts bytes target     prot opt in     out     source               destination
1        2   120 MARK       all  --  tun12  *       0.0.0.0/0            0.0.0.0/0            MARK xset 0x1/0x7
        Port Forward
<nas-deluge-movies>8112>192.168.1.23>8112>TCP><nas-deluge-tv>8113>192.168.1.23>8113>TCP><nas-radarr>7878>192.168.1.23>7878>TCP><nas-sonarr>8989>192.168.1.23>8989>TCP><nas-dsm>5000>192.168.1.23>5000>TCP><nas-plex>32400>192.168.1.23>32400>TCP><FTP Server>20,21>192.168.1.23>21>TCP><http>80>192.168.1.23>80>TCP><https>443>192.168.1.23>443>TCP>
Interestingly my WAN IP is actually incorrect in that output (instead of XXX.YYY.ZZZ.AAA it is shown as XXX.YYY.ZZZ.1, marked as `the_ip` in the above). Does that mean anything ?
   RPDB Rules
        Table main
        FWMARK Tagging
        Port Forward
First observation you have not ENABLED Selective Routing as evidenced by
I suggest you ENABLE Selective Routing in the GUI and assuming you want ALL LAN traffic to default via VPN Client 2 - but ensure the router itself is always via the WAN
then recheck the rules
Did your manipulation thank you for that. Stupidly thought the nat-start script took precedence over the GUI. The dropdown menu was on Policy Rules but not strict and the table below was empty.
I only want to filter some ports coming from my NAS (sitting at 192.168.1.23) so I have done the below :
The new output of your one liner is now :
        RPDB Rules
10201:  from 192.168.1.1 lookup main
10301:  from 192.168.1.23 lookup ovpnc2
10.7.5.0/24 dev tun12  proto kernel  scope link  src 10.7.5.2
default via 10.7.5.1 dev tun12
        Table main
        FWMARK Tagging
Chain PREROUTING (policy ACCEPT 1757 packets, 663K bytes)
1      100 15023 MARK       all  --  tun12  *       0.0.0.0/0            0.0.0.0/0            MARK xset 0x1/0x7
        RPDB Rules
        Table main
        FWMARK Tagging
OK, so the VPN Client 2 default gateway is now via VPN tun12 interface (10.7.5.1) rather than the WAN eth0 interface
If you only want to route ALL traffic from a single device (192.168.1.23) via the VPN then you don't need the explicit router rule via the WAN as that is the default anyway.
So now it appears nat-start hasn't run correctly to create the RPDB rules, and the fwmark mark tagging rule for Selective Port routing.
you should manually rerun nat-start
cd /jffs/scripts
./nat-start
Thank you.
I would like to route only specific ports traffic from 192.168.1.23 to the VPN, [the rest of the ports on 192.168.1.23] and [all the other devices] should run through WAN (the default as you mention). Not ALL traffic from this device.
When I try to manually run the script :
Do I need to run it as root ?
Run
dos2unix /jffs/scripts/nat-start
then retry.
You should remove the NAS (192.168.1.23) entry from the Selective Routing GUI
Ahah that's why the table was empty then ! :)
Thks for the dos2unix trick. I ran the script but unfortunately it didn't seem to do anything as my IP tracker still indicates my WAN IP.
The output of your one liner is now :
        RPDB Rules
9990:   from all fwmark 0x8000/0x8000 lookup main
9991:   from all fwmark 0x7000/0x7000 lookup ovpnc4
9992:   from all fwmark 0x3000/0x3000 lookup ovpnc5
9993:   from all fwmark 0x1000/0x1000 lookup ovpnc1
9994:   from all fwmark 0x2000/0x2000 lookup ovpnc2
9995:   from all fwmark 0x4000/0x4000 lookup ovpnc3
        Table main
        FWMARK Tagging
Chain PREROUTING (policy ACCEPT 24655 packets, 21M bytes)
1        1    60 MARK       all  --  tun12  *       0.0.0.0/0            0.0.0.0/0            MARK xset 0x1/0x7
2        0     0 MARK       tcp  --  br0    *       0.0.0.0/0            0.0.0.0/0            source IP range 192.168.1.23-192.168.1.23 multiport dports 8112,8113 MARK or 0x2000
the_ip still does not match my actual WAN IP though. Should I care ?
Looks like the rules are now active. Do I need to restart my router ?
        RPDB Rules
        Table main
        FWMARK Tagging
Only use a native unix LF aware editor, i.e. notepad++ or if using windows, install WinSCP then use its internal editor, or use the router's nano editor.
Well it depends.....if you are double NAT etc. but clearly if you are able to surf the Internet then does it matter?
No
So finally the Selective Port Routing environment is almost correct... i.e. I don't know why this
route that you previously had before shown in post #6 is now missing? (you may need to add a dummy entry say 172.16.2.1 to the Selective Routing GUI)
Anyway, you now need to generate traffic for the destination ports 8112/8113 from the NAS to see if there are hits on the fwmark tagging rule.
Thanks again for your detailed replies.
I only asked in case it was an issue to redirect the traffic. Clearly, as long as the redirection through the VPN works I don't care :)
The only difference is I emptied the table again (removing the WAN default for the router and the 192.168.1.23 rule). Shall I put in the WAN default for the router again ? Even though it should not matter one iota for this.
There is constant traffic through those ports.
The output is now (after adding the dummy entry in the GUI):
        RPDB Rules
10301:  from 172.16.2.1 lookup ovpnc2
        Table main
        FWMARK Tagging
Chain PREROUTING (policy ACCEPT 3172 packets, 392K bytes)
hi I'm new in the forum,i have a problem with policy rules,sometimes they work most of the time they don't work,I can't understand the cause of the problem ipv6 disabled automatic ip please help me or an rt-ac86u fails to establish the client when imposed on political rules
maybe create your own thread since this seems to be a different issue ?
I would try inserting the dummy GUI entry (then restart VPN Client 2), if that doesn't work, then you could reinstate the redundant 'router via WAN' entry.
Well according to the iptables rule above, there is no TCP port 8112/8113 outbound from 192.168.1.23 that is to be redirected via the VPN Client?
So either the source IP / destination Ports / protocol are incorrect or the hardware acceleration feature is bypassing the iptables tagging rule.
As you can see in my post above the
is back
I am fairly sure that the source IP and ports are correct.
How would I test protocol and/or hardware acceleration bypassing the iptables tagging ?
is back
Just to make sure, I tested adding a rule in the GUI to route ALL traffic from 192.168.1.23 through the VPN and it works so at least the source IP is correct. And I have specifically forwarded those ports through the GUI as well so reasonnably confident the ports are correct as well.
is back
You can test if the VPN redirect is working
e.g. temporarily redirect standard Web URL HTTP/HTTPS TCP ports 80/443 via VPN Client 2 for your laptop xxx.xxx.xxx.xxx
iptables -t mangle -A PREROUTING -i br0 --src xxx.xxx.xxx.xxx -p tcp -m multiport --dport 80,443 -j MARK --set-mark 0x2000/0x2000
then browse a few websites, and check if there are hits in the fwmark tagging rule.
Use the following command to remove the temporary Web URL rediection.
iptables -t mangle -D PREROUTING -i br0 --src xxx.xxx.xxx.xxx -p tcp -m multiport --dport 80,443 -j MARK --set-mark 0x2000/0x2000
GUI Port Forwarding is inbound from the WAN:rolleyes::rolleyes:
Damn I knew it was something stupid !
Tested the above and it shows correct redirection. Thank you so much for figuring out that PEBKAC :)
So the command for outbound redirection would then be :
iptables -t mangle -D PREROUTING -i br0 --src 192.168.1.23 -p tcp -m multiport --dport 8112,8113 -j MARK --set-mark 0x2000/0x2000
Do I need to add that to the nat-start script for it not to be lost on router restart or whatnot ?
NO!
The '-D' means delete the iptables rule, it has nothing to do with (inbound/outbound) 'direction'.
I have no idea what NAS application uses destination port 8112/8113, but if you are trying to host a 'hidden' service on your NAS that can only be accessed by 'your friends' inbound through the VPN Client 2 tunnel, then you need to customise other features....
i.e. Does your VPN ISP actually allow unsolicited traffic requests inbound via the VPN Client 2 tunnel to your LAN? - most don't.
However, if it does then you will need to setup the port forward rules(s) on the VPN ISP's dashboard, and enable VPN inbound firewall on the router etc.
Good luck.
