Hello, i recently had to rearrange my house and now i am forced to connect my PC to the local lan with wifi, my PC motherboard has Intel AX200 and it is connected at 5ghz to a TP-Link 225v3 AP.
When i upload a file to another PC on the local lan the transfer rate is around 70Mbytes/s which is enough for my needs. My problem is that when i download a file from another PC on the lan the transfer rate is 25 Mbytes/s which is less than what i need.
When testing i moved my PC closer to the AP and the speed went up so i think that the EAP225v3 signal just isn't strong enough while my PC AX200 signal is just fine. Also when i connect a laptop on the same AP and transfer files from my PC the speed is even lower ( 20 Mbytes/s) because the AP is used by both devices.
I plan to replace the AP with something with stronger signal and the ability to maintain high speed when two devices is using it. I know that a 400 euro router would do the job but i was hoping for a less expensive solution, at the same time i don't want to risk buying something cheap and having weak signal again.
What would you suggest me to buy and replace the AP;
