Hi, I need alittle advice and help on which router to get. I am in the need of a new wireless router as the one I have now is pretty old and slow. When I try streaming HD over the Internet it is very slow and choppy. I am looking for a pretty good one that will handle HD streaming like Netflix. I am also going to be setting it up and using it with a VPN service, privateinternetaccess.com From my research and what I have it sounds like the Asus AC68U and Asus AC87U are probably the best routers. The 87U is the new quad stream router and is supposed to be the best router on the market. The first question I have is should I get the AC68U or is it worth paying the difference and getting the AC87U. Or is there a better router to get.
The other question I have is once I get the new router and VPN service set up and running do I still need a anti virus and firewall program or will I need not need them anymore because of the router and VPN service. By the sounds of it the AC87U has security built into it already. I don't want to pay for a antivirus and firewall program if the routers have it built into them.don't want to pay for a antivirus and firewall program if the routers have it built into them.
The last question I got is if I should go with the AC87U router what is the best quad stream client adapter to get for it. This is going to be a costly adventure so I want to make sure I get the right one. Thanks for any advice and help you can provide.
