Need help/advice for RT-AX3000 and Verizon 5g home setup
lepa71
Hi. I'm debating on how to set up verizon 5g home ASK-NCM1100 and RT-AX3000. I had a previous model from Verizon and had it as IP Passthrough. It only had 2.4 and 5 bands, but new one has 6. I would like to keep 6 band open but then I can't use IP Passthrough, which is ok, but the problem is that the device connected to 6 band can't connect to RT-AX3000. So how can I configure ASK-NCM1100 to see RT-AX3000?
