Need help after switching from regular cable to fiber
danart
I need your help guys.
My house was built in 2018 with no ethernet, just RG6 cables to each room terminating in the garage, 6 cables in total. With my previous cable internet provider i had a total of 6 Actiontec ECB6200 in every room. Cable will enter the box in the garage. I had a MOCA filter installed to the 6 ports 5-1002 Mhz splitter. The router was installed in one of the upstairs rooms, everything worked properly with no problems whatsoever.
When fiber internet provider came to our neighborhood i decided to switch to fiber 500/500. Fiber point of entry was in the same cable box in the garage. I moved the router in the garage connected to ONT. I also have an Actiontec ECB6200 connected to a LAN router's port with a patch cable and coax out to the same filter and same splitter like before.
The problem is that the MOCA adapter in the garage cannot communicate with the ones in the house. In one of the rooms i have an ASUS AiMesh router as a node. This node will only connect to the main router in the garage thru wireless. AiMesh node can see all the MOCA adapters and devices upstairs. I cannot establish an ethernet backhaul to the router in the garage.
Help !
This should be your issue, that you didn't reconnect the router's MoCA bridge "like before" -- which would have the router's MoCA bridge still connected via one of the output ports of the splitter. With the router moved to the garage and with its MoCA bridge now connected to the splitter's INPUT port via the "PoE" MoCA filter, the MoCA signals are being impeded by the MoCA filter doing what it's designed to do ... BLOCK MoCA signals.
See this related reply for your options ...
edit: p.s. There’s also the potential for using MoCA to extend the ONT’s WAN link inside the house, to allow relocation of the router.
If/when you need to update this splitter (like if you shift to using MoCA 2.5, need 7+ output ports, or just want a model with known specs in the MoCA frequency range), be sure to use a model optimized for MoCA 2.x.
Thank you for your help. Yes, installing MOCA adapter before filter was silly. I removed the filter and connected the garage MOCA adapter straight to the splitter. Now there is another issue, the internet including wireless side bogs down like every 15 sec. Same with another 6-way BAMF 5-2300Mhz splitter. For now i removed the 5-1002 Mhz 6-way splitter and replaced it with an 3-way splitter i had in my house with same range. Now the ethernet backhaul is working properly but, if possible, i still want to use all MOCA adapters i have.
You may want to use the topology recommended in the linked comment, as well as a MoCA-optimized splitter. (i.e. all MoCA nodes off outputs, “PoE” MoCA filter and 75-ohm terminator on input port; would allow for 5 connected remote locations with current 6-way, 6 if a 2-way is hung off one output port; basically, reverting to the prior working topology)
Same with another 6-way BAMF 5-2300Mhz splitter. For now i removed the 5-1002 Mhz 6-way spkitter
If I had to choose between the two, if the “PoE” MoCA filter will be installed on its input port, I’d start by trying the BAMF splitter, since the MoCA filter’s reflective benefit should obviate the sub-optimal port isolation specs of the BAMF splitter.
Wow, moving the garage MOCA adapter to the output side of the splitter, I didn’t think about that. I’ll try with the BAMF splitter and cap the PoE filter on the input side, and let you know. Thanks.
