Hello everyone
I'm trying to set up QoS and right now I can't make the following simple rule to work:
I leave my utorrent downloading at max speed.
Whenever I need to use port 80 (browsing or downloading from the web) utorrent would slow downloading to prioritize the whatever's needed on port 80. Once there's no traffic on 80 - torrents would resume to whatever's allowed as full speed. Really simple.
Right now if I do that then my download on 80 is only at 10-20% (when I know it can be over 60% if I slowed down utorrent). I tried both - enabling QoS without adding the port used for incoming connections (I don't use PnP) and with the default QoS settings (where I heard people say you just need to set port 80 to high priority and it will automatically be above utorrent when it comes to traffic). My utorrent is not using a random port each start (I checked my firewall and it said that port you enter in utorrent is the "TCP IN" port through which I get data/download). I also checked the TCP OUT port in the firewall which is used to share/upload, it was in the 40k-65k range and random for every connection. I don't really know what that means but that's what I found out.
I feel like it's hard for the QoS to grasp which traffic belongs to utorrent, I have yet to find a QoS guide that controls bittorent traffic in an effective way.
Sorry for the rant, I'm pulling out my hair here trying to make this thing work as I want it to.
