Need help! RT-AC66U
Amacron
OK I am extremely disappointed in this router. I have had nothing but problems. I am currently running firmware 3.0.0.4.374_130. I have run merlins fw from 24 all the way thru 32 beta 3.. I am not really sure what has changed it used to work fine with the occasional drop out. I am computer literate but not really when it comes to the router and what or how to configure it properly for optimize results. I have metageek inSSIDer 3 home version on my windows PC. I also have iphone, ipad Imac. The only device I have wired directily to the router is the imac. insidder show no overlapping signals its max rate for both the 2.4 and 5 band show 450.
I just ran speetest.net with bismol results ping is 87 registers .02 Mbps download and o upload on the 5 ghtz band. the fw is stock I have not done any changes except change the name of the SSID and password.
the Signal on the SSIDDER for the 2.4 band is -25 and for the 5 is -44.
I have restarted all my computers and still nothing.
Please help I wil take any and all suggetions.
Ps when I first dowloaded merlines 31 fw it was fast rock solid and never droped a connection. Then 2 days later the it started dropping the internet all the time.
Here is the log:
Jan 1 00:00:11 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Jan 1 00:00:11 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Jan 1 00:00:11 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Jan 1 00:00:11 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Jan 1 00:00:11 kernel: Using 300.000 MHz high precision timer.
Jan 1 00:00:11 syslog: module ledtrig-usbdev not found in modules.dep
Jan 1 00:00:11 syslog: module leds-usb not found in modules.dep
Jan 1 00:00:11 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jan 1 00:00:11 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 00:00:11 kernel: Mount-cache hash table entries: 512
Jan 1 00:00:11 kernel: PCI: Initializing host
Jan 1 00:00:11 kernel: PCI: Reset RC
Jan 1 00:00:11 kernel: PCI: Fixing up bus 0
Jan 1 00:00:11 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Jan 1 00:00:11 kernel: PCI: Fixing up bridge
Jan 1 00:00:11 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Jan 1 00:00:11 kernel: PCI: Fixing up bus 1
Jan 1 00:00:11 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Jan 1 00:00:11 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Jan 1 00:00:12 kernel: PCI: Fixing up bus 2
Jan 1 00:00:12 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:12 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Jan 1 00:00:12 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:12 kernel: highmem bounce pool size: 64 pages
Jan 1 00:00:12 kernel: pflash: found no supported devices
Jan 1 00:00:12 kernel: Boot partition size = 262144(0x40000)
Jan 1 00:00:12 kernel: Creating 2 MTD partitions on "sflash":
Jan 1 00:00:12 kernel: 0x00000000-0x00040000 : "pmon"
Jan 1 00:00:12 kernel: 0x001f0000-0x00200000 : "nvram"
Jan 1 00:00:12 kernel: Found a Zentel NAND flash with 2048B pages or 128KB blocks; total size 128MB
Jan 1 00:00:12 kernel: lookup_nflash_rootfs_offset: offset = 0x0
Jan 1 00:00:12 kernel: nflash: squash filesystem with lzma found at block 9
Jan 1 00:00:12 kernel: Creating 4 MTD partitions on "nflash":
Jan 1 00:00:12 kernel: 0x00000000-0x02000000 : "linux"
Jan 1 00:00:12 kernel: 0x00132ea0-0x02000000 : "rootfs"
Jan 1 00:00:12 kernel: 0x04000000-0x06000000 : "linux2"
Jan 1 00:00:12 kernel: 0x04132ea0-0x06000000 : "rootfs2"
Jan 1 00:00:12 kernel: Creating 3 MTD partitions on "brcmnand":
Jan 1 00:00:12 kernel: 0x00000000-0x02000000 : "trx"
Jan 1 00:00:12 kernel: 0x02000000-0x04000000 : "jffs2"
Jan 1 00:00:12 kernel: 0x04000000-0x07f00000 : "brcmnand"
Jan 1 00:00:12 kernel: dev_nvram_init: _nvram_init
Jan 1 00:00:12 kernel: _nvram_init: allocat size= 65536
Jan 1 00:00:12 kernel: u32 classifier
Jan 1 00:00:12 kernel: OLD policer on
Jan 1 00:00:12 kernel: Netfilter messages via NETLINK v0.30.
Jan 1 00:00:12 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Jan 1 00:00:12 kernel: ipt_time loading
Jan 1 00:00:12 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:12 kernel: net/ipv4/netfilter/tomato_ct.c [Aug 1 2013 15:44:46]
Jan 1 00:00:12 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:12 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:12 kernel: Warning: unable to open an initial console.
Jan 1 00:00:12 kernel: Failed to execute /sbin/preinit. Attempting defaults...
Jan 1 00:00:12 kernel: ctf: module license 'Proprietary' taints kernel.
Jan 1 00:00:12 kernel: et_module_init: passivemode set to 0x0
Jan 1 00:00:12 kernel: et_module_init: et_txq_thresh set to 0x400
Jan 1 00:00:12 kernel: bcm_robo_enable_switch: EEE is disabled
Jan 1 00:00:12 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.102.9 (r366174)
Jan 1 00:00:12 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Jan 1 00:00:12 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.102.9 (r366174)
Jan 1 00:00:12 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Jan 1 00:00:12 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.102.9 (r366174)
Jan 1 00:00:12 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:12 kernel: SCSI subsystem initialized
Jan 1 00:00:12 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c0209000
Jan 1 00:00:12 kernel: NTFS (with native replay) support included
Jan 1 00:00:12 kernel: optimized: speed
Jan 1 00:00:12 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Jan 1 00:00:15 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Jan 1 00:00:15 stop_nat_rules: apply the redirect_rules!
Jan 1 00:00:15 WAN Connection: ISP's DHCP did not function properly.
Jan 1 00:00:15 RT-AC66U: start httpd
Jan 1 00:00:16 miniupnpd[329]: HTTP listening on port 56614
Jan 1 00:00:16 miniupnpd[329]: Listening for NAT-PMP traffic on port 5351
Jan 1 00:00:17 stop_nat_rules: apply the redirect_rules!
Jan 1 00:00:18 kernel: nf_conntrack_rtsp v0.6.21 loading
Jan 1 00:00:18 kernel: nf_nat_rtsp v0.6.21 loading
Jan 1 00:00:18 rc_service: udhcpc 332:notify_rc stop_upnp
Jan 1 00:00:18 rc_service: udhcpc 332:notify_rc start_upnp
Jan 1 00:00:18 rc_service: start_upnp is waitting stop_upnp...
Jan 1 00:00:19 kernel: Ebtables v2.0 registered
Jan 1 00:00:20 WAN Connection: WAN was restored.
Jan 1 00:00:22 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.102.9 (r366174)
Jan 1 00:00:22 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.102.9 (r366174)
Jan 1 00:00:22 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Jan 1 00:00:28 miniupnpd[329]: received signal 15, good-bye
Jan 1 00:00:29 rc_service: udhcpc 332:notify_rc stop_ntpc
Jan 1 00:00:29 rc_service: stop_ntpc is waitting start_upnp...
Jan 1 00:00:29 miniupnpd[457]: HTTP listening on port 47811
Jan 1 00:00:29 miniupnpd[457]: Listening for NAT-PMP traffic on port 5351
Jan 1 00:00:30 rc_service: udhcpc 332:notify_rc start_ntpc
Jan 1 00:00:30 rc_service: start_ntpc is waitting stop_ntpc...
Jan 1 00:00:31 dhcp client: bound 74.128.97.249 via 74.128.96.1 during 75559 seconds.
Aug 23 20:04:52 rc_service: ntp 458:notify_rc restart_upnp
Aug 23 20:04:52 miniupnpd[457]: received signal 15, good-bye
Aug 23 20:04:52 miniupnpd[467]: HTTP listening on port 53168
Aug 23 20:04:52 miniupnpd[467]: Listening for NAT-PMP traffic on port 5351
Aug 23 20:06:07 rc_service: httpd 307:notify_rc start_autodet
Aug 23 20:06:10 rc_service: httpd 307:notify_rc start_autodet
Aug 23 20:06:27 rc_service: httpd 307:notify_rc start_autodet
Aug 23 20:07:03 rc_service: httpd 307:notify_rc chpass
Aug 23 20:07:04 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Aug 23 20:07:06 rc_service: httpd 307:notify_rc restart_ftpsamba
Aug 23 20:07:06 FTP Server: daemon is stoped
Aug 23 20:07:06 Samba Server: smb daemon is stoped
Aug 23 20:07:06 Samba Server: daemon is started
Aug 23 20:07:10 rc_service: httpd 307:notify_rc restart_wireless
Aug 23 20:07:15 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.102.9 (r366174)
Aug 23 20:07:15 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.102.9 (r366174)
Aug 23 20:07:16 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Aug 23 20:07:23 rc_service: httpd 307:notify_rc start_webs_update
Aug 23 20:07:27 kernel: eth2: received packet with own address as source address
Aug 23 20:07:27 dnsmasq-dhcp[306]: Ignoring domain us.tgr.net for DHCP host name LOUCLD2594B
Aug 23 20:07:49 nmbd[488]: [2013/08/23 20:07:49, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Aug 23 20:07:49 nmbd[488]: Samba name server RT-AC66U is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.1
Aug 23 20:08:01 rc_service: httpd 307:notify_rc restart_time
Aug 23 20:08:01 kernel: klogd: exiting
Aug 23 20:08:01 syslogd exiting
Aug 23 16:08:01 syslogd started: BusyBox v1.17.4
Aug 23 16:08:01 RT-AC66U: start httpd
Aug 23 16:08:01 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Aug 23 16:08:01 kernel: klogd started: BusyBox v1.17.4 (2013-08-01 15:42:16 CST)
Aug 23 20:12:53 nmbd[488]: Samba name server RT-AC66U is now a local master browser for workgroup WORKGROUP on subnet 74.128.97.249
Aug 23 20:22:38 dnsmasq-dhcp[306]: Ignoring domain us.tgr.net for DHCP host name LOUCLD2594B
Post a log section showing what happens when the Internet connection drops.
Amacron
Disappointed? I'm afraid you won't be able to find anything better except ASUS ARM-based routers (RT-AC68U which is yet unreleased).
