Home: 5400 sq ft 2 story home with street-level entrance to main living area on 2nd floor
completely open floor plan except master bedroom, only exterior 2x6 & stucco wall
pool on first floor wifi Zodiaq controller connected via wifi
Cat 5e cable in most rooms
Internet: 300/30 cable modem, speed tests at 345/25 wired
Previous setup: WRT1900AC on second floor, about 60 ft from pool controller, TP-Link Archer C7 on first floor
Current setup: Google Wifi 3-pack, main unit in theater room (1st floor, buried in layers of walls), one in kitchen (2nd), one in master bedroom (2nd), all 1000BT backhauls
The WRT1900 got full rated WAN speed with wireless AC within about 10-15 feet, but even about 35-40 feet with no walls, down to about 290 Mbps. I thought I would try a mesh network, so I bought the Google Wifi 3-pack, expecting better coverage and performance, but it's WORSE, down to 60-100 Mbps now within a few feet of any AP. Also, network testing on the Google Wifi app with 1000BT backhauls only gets about 130-160 Mbps. But at this point the worst part is my pool controller (Zodiaq iAqualink v1) no longer connects to my wifi network.
So I was going to go back to using regular wifi routers in AP mode, but this time researching the longest 2.4GHz range. So on CNET the king of long range 2.4 GHz is the Asus RT-AC68U, head and shoulders above all other routers at 100 ft. But on SNB it doesn't test out that stellar. So how do I interpret SNB's attenuation vs. other sites' distance? How do I select the best long range 2.4 GHz router?
Thanks in advance.
Thanks in advance.
