Hey guys. I'm feeling pretty stupid here to even have to post this.... I would love any advice as to what I'm missing.
I have a cable connection with cable modem, and 2x RT-AC86u's... I was running AiMesh but kept running into dropped clients and finally decided to roll AP mode over AiMesh to see if it helps.
I have not been successful setting up AP mode... just generally... do I setup both routers individually and separate from one another? Also does one go in Router mode and the other in AP mode? Or are they both going into AP mode? Also, if the 2nd router (slave) going LAN port on master to WAN port on slave? Or does it plug into the slaves LAN? Sorry for the dumb questions I've just found no guides online to setting them up this way.... only AiMesh...
My plan is to use the same SSID's and different static channels for the 4 wifi bands, and setup handoff minimum decibles to control them. I may need to reduce transmit power for this to be effective but I'll cross that bridge later.
Any help, and configuration advice is so appreciated!
