Need help to choose a router
York71
I need to purchase a dual-WAN router but I'm having a problem to find out which one do I need. My present situation is like this:
WAN1 - provided by BT throught 2Wire Gateway router, connection type: PPPoA
WAN2 - tooway Satelite internet
I would like to put both of the lines in load balancing mode. I thought I can turn WAN1 in bridge mode and configure it on dual-WAN router but not sure which one I should choose, is Vigor 2830 fine for this purpose? It needs to have Wi-Fi access also.
Any advice would be appreciated
Cheers,
York71
W I need some help with a new router and network card Routers 12
Z Router recommendation need. Routers 26
