I have Asus AC68U with Merlin v384.13. I want to restrict the devices, which are connected to LAN4 to access the MiniDLNA server on the router (192.168.10.1) It will be good if the SAMBA server is restricted as well, but it is not crucial as it is password protected.
I found the following code in the forum
It is good, but I noticed that I do not see the device on LAN4 anywhere in the ASUS webpage - they are missing in the clients list, Bandwidth Monitor, etc. I also want to have access to Devices on LAN4 from the devices on Wireless, LAN 1-3
Thank you in advance for your help.
# force LAN port 4 to use the Guest Network for RT-AC68U
robocfg vlan 1 ports "1 2 3 5t"
robocfg vlan 10 ports "4 5t"
vconfig add eth0 10
ifconfig vlan10 up
brctl addif br0 vlan10
ebtables -t broute -I BROUTING -p IPv4 -i vlan10 --ip-dst 192.168.1.0/24 --ip-proto tcp -j DROP
ebtables -t filter -I FORWARD -i vlan10 -o ! eth0 -j DROP
ebtables -t filter -I FORWARD -i ! eth0 -o vlan10 -j DROP
