Need Help, Wireless showing Disabled
Kaz
I am having problem from this morning with my wireless connectivity it shows as disabled, However I cant turn back, Can someone help me please.
I have firmware version 384.5
Asus-wrt- Merlin
Found solution:
It kind of weird, I went to Wireless>Professional Setting Under Enable Radio, it was turned off. I would like to know what happened, is it possible by taking a look at the log
Kaz
I managed to find the log
Feb 13 19:00:15 syslogd started: BusyBox v1.25.1
Feb 13 19:00:15 kernel: klogd started: BusyBox v1.25.1 (2018-05-12 21:53:16 EDT)
Feb 13 19:00:15 kernel: Linux version 2.6.36.4brcmarm ([email protected]) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Sat May 12 22:03:28 EDT 2018
Feb 13 19:00:15 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Feb 13 19:00:15 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Feb 13 19:00:15 kernel: Machine: Northstar Prototype
Feb 13 19:00:15 kernel: Ignoring unrecognised tag 0x00000000
Feb 13 19:00:15 kernel: bootconsole [earlycon0] enabled
Feb 13 19:00:15 kernel: Memory policy: ECC disabled, Data cache writealloc
Feb 13 19:00:15 kernel: MPCORE found at 19020000
Feb 13 19:00:15 kernel: PERCPU: Embedded 7 pages/cpu @c8215000 s5472 r8192 d15008 u65536
Feb 13 19:00:15 kernel: pcpu-alloc: s5472 r8192 d15008 u65536 alloc=16*4096
Feb 13 19:00:15 kernel: pcpu-alloc: [0] 0 [0] 1
Feb 13 19:00:15 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60416
Feb 13 19:00:15 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Feb 13 19:00:15 kernel: PID hash table entries: 1024 (order: 0, 4096 bytes)
Feb 13 19:00:15 kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Feb 13 19:00:15 kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Feb 13 19:00:15 kernel: Memory: 128MB 128MB = 256MB total
Feb 13 19:00:15 kernel: Memory: 255488k/255488k available, 6656k reserved, 0K highmem
Feb 13 19:00:15 kernel: Virtual kernel memory layout:
Feb 13 19:00:15 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Feb 13 19:00:15 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Feb 13 19:00:15 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Feb 13 19:00:15 kernel: vmalloc : 0xd0800000 - 0xf0000000 ( 504 MB)
Feb 13 19:00:15 kernel: lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
Feb 13 19:00:15 kernel: modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Feb 13 19:00:15 kernel: .init : 0xc0008000 - 0xc003d000 ( 212 kB)
Feb 13 19:00:15 kernel: .text : 0xc003d000 - 0xc03aa000 (3508 kB)
Feb 13 19:00:15 kernel: .data : 0xc03c2000 - 0xc03e52e0 ( 141 kB)
Feb 13 19:00:15 kernel: SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Feb 13 19:00:15 kernel: * Invalid signature of oopsbuf: FF-FF-FF-FF-FF-FF-FF-FF (len 4294967295)
Feb 13 19:00:15 kernel: Hierarchical RCU implementation.
Feb 13 19:00:15 kernel: RCU-based detection of stalled CPUs is disabled.
Feb 13 19:00:15 kernel: Verbose stalled-CPUs detection is disabled.
Feb 13 19:00:15 kernel: NR_IRQS:256
Feb 13 19:00:15 kernel: MPCORE GIC init
Feb 13 19:00:15 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
Feb 13 19:00:15 kernel: MPCORE Global Timer Clock 400000000Hz
Feb 13 19:00:15 kernel: Calibrating delay loop... 1599.07 BogoMIPS (lpj=7995392)
Feb 13 19:00:15 kernel: pid_max: default: 32768 minimum: 301
Feb 13 19:00:15 kernel: Mount-cache hash table entries: 512
Feb 13 19:00:15 kernel: CPU: Testing write buffer coherency: ok
Feb 13 19:00:15 kernel: MPCORE Private timer setup CPU0
Feb 13 19:00:15 kernel: Calibrating local timer... 399.884MHz.
Feb 13 19:00:15 kernel: L310: cache controller enabled 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x7a130000
Feb 13 19:00:15 kernel: CPU1: Booted secondary processor
Feb 13 19:00:15 kernel: MPCORE Private timer setup CPU1
Feb 13 19:00:15 kernel: Brought up 2 CPUs
Feb 13 19:00:15 kernel: SMP: Total of 2 processors activated (3198.15 BogoMIPS).
Feb 13 19:00:15 kernel: devtmpfs: initialized
Feb 13 19:00:15 kernel: atomic64 test passed
Feb 13 19:00:15 kernel: NET: Registered protocol family 16
Feb 13 19:00:15 kernel: Found a AMD NAND flash:
Feb 13 19:00:15 kernel: Total size: 128MB
Feb 13 19:00:15 kernel: Block size: 128KB
Feb 13 19:00:15 kernel: Page Size: 2048B
Feb 13 19:00:15 kernel: OOB Size: 64B
Feb 13 19:00:15 kernel: Sector size: 512B
Feb 13 19:00:15 kernel: Spare size: 16B
Feb 13 19:00:15 kernel: ECC level: 8 (8-bit)
Feb 13 19:00:15 kernel: Device ID: 0x 1 0xf1 0x80 0x1d 0x 1 0xf1
Feb 13 19:00:15 kernel: CCA UART Clock Config: Sel=1 Ovr=1 Div=48
Feb 13 19:00:15 kernel: CCA UART Clock rate 100000000Hz
Feb 13 19:00:15 kernel: bio: create slab <bio-0> at 0
Feb 13 19:00:15 kernel: Switching to clocksource mpcore_gtimer
Feb 13 19:00:15 kernel: NET: Registered protocol family 2
Feb 13 19:00:15 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Feb 13 19:00:15 kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Feb 13 19:00:15 kernel: TCP bind hash table entries: 8192 (order: 4, 98304 bytes)
Feb 13 19:00:15 kernel: TCP: Hash tables configured (established 8192 bind 8192)
Feb 13 19:00:15 kernel: TCP reno registered
Feb 13 19:00:15 kernel: UDP hash table entries: 128 (order: 0, 4096 bytes)
Feb 13 19:00:15 kernel: UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
Feb 13 19:00:15 kernel: PCI: no core
Feb 13 19:00:15 kernel: PCI: scanning bus 0
Feb 13 19:00:15 kernel: PCI: Fixing up bus 0
Feb 13 19:00:15 kernel: PCIE1 link=1
Feb 13 19:00:15 kernel: PCIE1 switching to GEN2
Feb 13 19:00:15 kernel: PCI: bus0: Fast back to back transfers disabled
Feb 13 19:00:15 kernel: PCI: Fixing up bus 1
Feb 13 19:00:15 kernel: PCI: bus1: Fast back to back transfers disabled
Feb 13 19:00:15 kernel: pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
Feb 13 19:00:15 kernel: pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
Feb 13 19:00:15 kernel: pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
Feb 13 19:00:15 kernel: pci 0001:00:00.0: PCI bridge to [bus 01-01]
Feb 13 19:00:15 kernel: pci 0001:00:00.0: bridge window [io disabled]
Feb 13 19:00:15 kernel: pci 0001:00:00.0: bridge window [mem 0x08000000-0x080fffff]
Feb 13 19:00:15 kernel: pci 0001:00:00.0: bridge window [mem pref disabled]
Feb 13 19:00:15 kernel: PCIE2 link=1
Feb 13 19:00:15 kernel: PCIE2 switching to GEN2
Feb 13 19:00:15 kernel: PCI: Fixing up bus 2
Feb 13 19:00:15 kernel: PCI: bus2: Fast back to back transfers disabled
Feb 13 19:00:15 kernel: pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
Feb 13 19:00:15 kernel: pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
Feb 13 19:00:15 kernel: pci 0002:02:00.0: BAR 0: set to [mem 0x40000000-0x40007fff 64bit] (PCI address [0x40000000-0x40007fff]
Feb 13 19:00:15 kernel: wl_module_init: igs set to 0x0
Feb 13 19:00:15 kernel: wl_module_init: txworkq set to 0x0
Feb 13 19:00:15 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.126 (r561982)
Feb 13 19:00:15 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.126 (r561982)
bbunge
Possible the WPS button was pushed. That can turn off the WIFI.
Might be a good idea for you to upgrade your firmware
Kaz
Thanks for the quick reply, I would like to know from looking at the log, was there something
L&LD
Part of the Furniture
What router are we talking about here? Yes, that firmware should have been put out to pasture a long time ago.
