Need help with open nat on edgerouter 4
Dorian Chamorro
I just picked up the ed4 and got it srt up and working great but my PC and xbox say they have a moderate nat. I looked up a few YouTube videos did exactly what they said and my nat level never changes. Can someone walk me through exactly each step. Because YouTube didn't work
I have an edge router lite. It was set up using this guide:
https://www.smallnetbuilder.com/lan...ow-to-configure-your-ubiquiti-edgerouter-lite
Since the ERL3 and the ER4 use the same CPU, the same config should work with yours.
I do not have a NAT problem with my setup.
Remember to Upgrade the firmware to 1.10.10 or to 2.0.8 .
I'm using 1.10 series as it does not have the UDP packet reordered bug of the 2.0 series
Enviado desde mi moto g(8) plus mediante Tapatalk
should i switch to 1.10.10 im on 2.08
If you do not have the UDP issue in something like ip phone's, stay in 2.0 Series.
By the way, I do not have the NAT issue you are reporting. All working just fine
Not sure what that is lol so im gonna guess it doesn't effect me
