Need IP addresses for Netflix and others for Policy Based Routing
DTS
How can I find the full list of the IP addresses to use for Netflix and other services (Hulu, Tidal, Pandora, etc.) when I enable policy-based routing as described in threads like this one?
For example, if I ping hulu.com, I get an IP address:
PING hulu.com (88.221.131.142)​
dig hulu.com gives me the same single IP address. But I'm sure they use multiple servers. So how do we find them all?
I've heard that dig is a way to do it. Here are my dig results for netflix:
dig netflix.com
netflix.com. 1 IN A 34.227.4.120
netflix.com. 1 IN A 34.232.235.235
netflix.com. 1 IN A 52.206.23.236
netflix.com. 1 IN A 34.236.214.109
netflix.com. 1 IN A 34.233.159.233
netflix.com. 1 IN A 107.23.104.215
netflix.com. 1 IN A 54.82.145.47
netflix.com. 1 IN A 52.3.32.33
However, compared to the reference post, every IP is different. None of them are in agreement.
Source IP 0.0.0.0 Destination IP 23.21.160.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 54.204.43.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 107.20.154.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 54.243.253.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 50.19.210.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 23.23.191.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 107.20.151.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 54.204.2.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 107.20.177.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 54.225.192.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 174.129.2.0/24 lface WAN
Source IP 0.0.0.0 Destination IP 75.101.139.0/24 lface WAN
Bottom line: how do we find the full list of IP addresses for a certain service for policy-based routing rules (in openvpn client)? It seems like many companies would want or need lists like this to block certain services from being used at work. I expected this would be an easy thing to look up, but I have not found it yet.
dig netflix.com
I need to update the README with this information.
You can lookup the ASN using the site https://bgp.he.net/AS6427. Type the name of the company you are looking for in the search box. For example, typing in Hulu returns a list which contains AS23286. You can then clone IPSET_Netflix.sh for the streaming service you want to selectively route. dnsmasq.log file is your friend. The method for mining dnsmasq is in the section IPSET_Netflix_Domains.sh
octopus Need some help I have set up vpn server => client VPN 14
