Just looking to see whats new, whats better than what i got, always wanting better performance. My latest after years of RTAC86U and then the AX
Now using the RTBE86U, no longer as good as it was, whats are people using these days.
Thanks for your input.
Need to be able to upload a nordvpn setup file, need to be able to decode encode like one of my older routers. And need to replace my existing 4 routers, so cant spend more that £400 ish each, and would need Wifi 6, or 6 and 7
Thanks, what you using?
Just ran a test on speed using the BE86U internal internet test 379.13 Mbps bypass VPN
If i go to speednet, ill be using VPN, speed is, 1st 10 Mbps, but i ignore first test, second test 173Mbps and most tests after on all 4 routers come out at 173, all routers use the latest servers for UK, and are in London.
I download the latest servers in London, from Nordvpn server list, then use 4 of the top numbers. Usally i get good results, but 173 use to be 230 6 months ago,?
All have latest Merlin firmware, yes i know one router no longer supported
