Need some help I have set up vpn server => client
octopus
Part of the Furniture
Hello guys.
Need some help I have set up vpn server => client (client is another brand router with vpn sw 2.6.14) and can't reach other side lan clients from server. (ping working though)
Client side have this:
LAN 192.168.46.0/24
option route_nopull '1'
list route '192.168.50.0 255.255.255.0'
Server side have this:
192.168.50.0/24
server 10.8.44.0 255.255.255.0
push "route 192.168.50.0 255.255.255.0 vpn_gateway 500"
route 192.168.46.0 255.255.255.0
I also have CCD file and ipp.txt
Hope someone have som suggestions.
So you can "ping" the VPN client-side hosts (192.168.46.x) but you can't "reach" them?
Yes it is strange.
PING 192.168.46.1 (192.168.46.1): 56 data bytes
64 bytes from 192.168.46.1: seq=0 ttl=64 time=6.170 ms
64 bytes from 192.168.46.1: seq=1 ttl=64 time=5.083 ms
64 bytes from 192.168.46.1: seq=2 ttl=64 time=5.030 ms
What do you mean by "reach" then if you can ping them?
If I try to reach GUI on client side I get no response, only with ping using MobaXterm
If I try to reach GUI on client side I get no response...
This is all a bit vague. What kind of GUI and what kind of device? What about other devices?
Does this device(s) have a firewall? If so, have you allowed traffic through from the VPN subnet (10.8.44.0/24)?
Yes it has. It's GL-MT6000
have you allowed traffic through from the VPN subnet (10.8.44.0/24)? => on client side?
