Need some help on creating a persistence cronjob
chinese_ys
I do have the "Format JFFS partition at next boot" set as No and "Enable JFFS custom scripts and configs" as Yes.
Under /jffs/scripts folder, I have a file called cronjobs as below:
-rwxrwxrwx 1 admin root 306 Oct 25 09:57 cronjobs*
Inside the cronjobs file, I have sample content below:
#!/bin/sh
cru a MoveFiles "*/30 * * * * mv /tmp/mnt/Files/* /tmp/mnt/Files/Temp/"
If I manually run the cronjobs file, the job is installed properly. But it doesnot seem like it would survive the reboot...Do I missed anything?
Adamm
Part of the Furniture
