Pros: None.I recently picked up this switch for 2.5Gb fiber internet and 2.5Gb Wifi 6 APs.
Is there a cheaper switch with similar features?Pros: None.
Cons: Highly overpriced. 3 Fans.
Also, if you need more ports, I can recommend the TRENDnet S380, which is 8 x 2.5G ports and otherwise the same. I've had one for about six months, and the only complaint I've had with it is I find it doesn't pass VLAN-tagged packets. It's not required to do so by any spec; but the Netgear switches I have will pass those, and I had to do some rearranging when I found out this one didn't.TRENDnet 5-Port Unmanaged 2.5G Switch, 5 x 2.5GBASE-T Ports, 25Gbps Switching Capacity, Backwards Compatible with 10-100-1000Mbps Devices, Fanless, Wall Mountable, Black, (TEG-S350)
That's interesting as dumb switches go back to the days of bridges and don't look at the traffic and just pass it along. I'm going to assume you did a hard reset on it to see if it would fix that issue?doesn't pass VLAN-tagged packets.
It's just a box, there's no "hard reset" other than the power plug. I was surprised about it too, but some googling suggested that this is common with some switch manufacturers. Maybe they are hoping to upsell you to a managed switch.That's interesting as dumb switches go back to the days of bridges and don't look at the traffic and just pass it along. I'm going to assume you did a hard reset on it to see if it would fix that issue?
I'm connecting 2 workstations that are 10G. I have 2.5G fiber internet that can be upgraded to 5G. The Wifi 6 APs are 2.5G and powered by POE+ and POE++. If I didn't get a POE switch, I'd have to find a 2.5G POE++ POE injector. I don't know if those exist, yet.If the gear you want to connect is all 2.5G max, you don't need a 10G-capable switch (unless maybe you've got a 10G-capable pipe you're trying to connect them all to?). The other questions to ask are whether you actually need a managed switch, or POE. Each of those things adds power budget and makes it more likely that you'll need something with fans in it. So ... what features do you actually need?
I use a 10ge poe injector because it's either 1 or 10 with no middle ground for nbaset speeds still unless you pay up significantly for a switch that does those speeds and poe. At $60 for an injector it didn't make sense to go with a switch. Now if you're doing 4+ devices that need poe and speed it makes a little more sense to go with a switch instead.I'm connecting 2 workstations that are 10G. I have 2.5G fiber internet that can be upgraded to 5G. The Wifi 6 APs are 2.5G and powered by POE+ and POE++. If I didn't get a POE switch, I'd have to find a 2.5G POE++ POE injector. I don't know if those exist, yet.
Procet 10G 10Gbps Power-Over-Ethernet Active PoE-Injector-Midspan 60W 55V, UL Certificate, for a New Range of Applications Including 802.11ax Access Points,WiFi 6,PT-PSE104GB-60-10 $69.00
The AP I've been looking at is the Netgear WAX630E. It has an optional power adapter you can get. But I need POE since I ceiling-mount my APs. I don't have random power outlets in the walls or ceiling-space. I'm looking at this switch which is similar to the Netgear GS110MX to use in 1 or 2 roomsWell ... unless you're shoving a lot of data directly between the two workstations, their 10G ports are doing nothing for you. You should probably have your eyes mostly on effective use of that 5G internet pipe you're planning to pony up for real soon. (Or if you're not about ready to do that, really you oughta just think about 2.5 all around.) Even with that service in place, what sites are you connecting to that will provide 5G data rates on a routine basis? I think the sales pitch for such a fat pipe is not that any one client will use the whole bandwidth, but that several clients can run pretty intensive transfers simultaneously. So you might want to think about an asymmetric switch with a 5G or 10G port that will go to your internet pipe, and mostly 2.5G ports otherwise. Gear like that does exist, for example I currently use some Netgear GS110MX switches with 2 10G ports and 8 1G ports.
POE++ all around is going to add a lot of cost and power budget that you aren't getting your money's worth out of, either. I'd push harder on the idea of using an injector for that high-power AP. Surely the AP's manufacturer has a recommended injector --- although if you go that route, you're paying top dollar for the assurance that it'll work. Might be worth getting a street-price POE++ injector from someplace that will let you return it, and see if it will pass 2.5G reliably. (My double-E degree is decades rusty, but my sense of the hardware situation is that a POE injector shouldn't much care what data speed you're pushing through it.)
https://www.amazon.com/dp/B08TC3VJ61/?tag=snbforums-20
Thread starter | Title | Forum | Replies | Date |
D | Netgear GS305EPP Port 4 Untrusted? | Switches, NICs and cabling | 5 | |
A | Just realised my Netgear switch does not support LACP or IEEE 802.3ad - does it matter? | Switches, NICs and cabling | 4 |
Welcome To SNBForums
