Netgear N600 model C3700 not connecting 5G
Steve40th
Hey, I am at Dads house, and his modem N600 Model 3700 has two channels, 2 SSIDs. His 5G network has the same ssid as the 2.4 side but doesnt seem to work.
I changed the SSID name, and password, and it will not connect at all. Even after rebooting.
The Network shows up on my laptop, but when I try to connect, it wont even give me a place to put password.
Right now i use inSSIder to review the signal, and it shows the signal coming from it, but no connection.
Xfinity internet, laptop is Windows 7 64 bit. 7260AC Intel chip.
What channel number are you currently using? Try manually setting the channel to 36 which should be compatible with all devices.
