Hello,
I'm running Merlin Build 3.0.0.4.220.18 which has been very rock solid. I recently had to configure OpenVPN (TAP) and needed to block DHCP requests from occuring across the tunnel. I created a firewall-start script and I can confirm that it is launching and running correctly (ebtables -L shows the proper rules).
My question is - even with the rules being applied, I see client computers on the other end displayed in the Network Map. I'm not sure how to interpret the network map client information.....is this DHCP lease data meaning that these machines are still getting a DHCP lease from within the tunnel or does the network map simply display devices that are detected via bonjour, etc?
Thanks!
Asus N66U
Thanks!
Asus N66U
