Been reading this site for years, but time to ask for some guidance. I live in a 2000 square foot single level home (long rectangle). My current setup is 250mb/s cable service into an Asus Rt68U router, into a 16 port Cisco unmanaged switch, with an ethernet backhaul to an Asus RT-66u at the far end of the house running as a WAP. I run everything I can by ethernet, which includes 4 desktops, two printers, two tvs, an intel nuc music server, and a sonos player. Running wireless are 3 iphones, 3 ipads, one sonos, two 4k tvs (can't get ethernet to them), and a couple of low use iot devices (sprinkler controller and thermostat). Occasionally there a laptop or two in there also.
As seems to be consistent, it has been two years since I last changed routers and they are starting to die. Long response times, devices can't connect, issues which are solved by a reboot for a short time, then come back. Firmware is up to date, it just seems these things die about every two years. I want something that lasts longer than that, is dead nuts reliable, and reasonably easy to use.
Looking around it seems like Ubiquiti looks like it may meet my needs. I like the cost of the AmpliFi router with one additional node, but am concerned I am looking at the same reliability. This leaves me looking at the UniFi. If I understand correctly, I would need the following for the UniFi:
Thank you
- Security Gateway
- Switch 8 60w (to run WAPs) better would be a 16 port POE, but if I understand correctly, I can keep my Cisco 16 port, it just won't show up as managed in the UniFi software.
- Cloud Key
- 2 AP AC Lite
Thank you
