I would start with 1x Cisco ASR 9910 Router and 10x Cisco Catalyst 9136 Access Points. Add extra if needed.
I really like the Nexus 9500's because one can never have enough ports... esp if one wants to have drops for the media center, bedrooms, closets, bathrooms, garage, the neighbors, etc...
@Tech9's feedback on the AP's - spot on...
The Cisco Nexus 9500 Series modular switches support a comprehensive selection of line cards and fabric modules that provide 1-, 10-, 25-, 40-, 50-, 100-, 200-, and 400-Gigabit Ethernet interfaces. Using these line cards the Cisco Nexus 9500 Series switches can be configured with up to.
- 256 400-Gigabit Ethernet ports (or)
- 524 200-Gigabit Ethernet ports# (or)
- 1024 100-Gigabit Ethernet ports (or)
- 2048 50-Gigabit Ethernet ports (or)
- 1024 40-Gigabit Ethernet ports (or)
- 2304 25-Gigabit Ethernet ports (or)
- 2304 1/10-Gigabit Ethernet ports
The ASR 9ks can do terabits of true routing, they are amazing edge routers.
Just make sure QoS is disabled and NAT acceleration is enabled.
When you speedtest 298Mbps on your 300Mbps ISP line - time to upgrade.
They come with no PoE injector. This makes them a little expensive for home use.
Happy to help. One more reason to get ASR 9K series router - @sfx2000 told me OpenWrt support is coming soon.
I would try LAGG with 2x 400-Gigabit ports. This may keep latency low with larger emails.
Don't overload the APs with 2-3 laptops checking mail at the same time and you're good.
Try your old RT-AC68U as AiMesh node if you need coverage to the garden or to your garage.
Don't use too many static IPs and too many client names - not sure what's ASR 9K NVRAM situation.
Please, run the stock firmware on your new system for now and see how stable it is. If you have stability issues - do factory reset few times.
They're starting to reuse the catalyst name (which used to be L2 and eventually L3 switches) for access points and routers which is making things really confusing.
Yeah - everything is a remix these days and hard to tell what's what with downloading the spec sheet/product brief.
We did the Nexus upgrade in a wireless telecom core consolidation (long story) replacing years of organic growth with a hodge podge of gear from Juniper, Brocade, etc...
That was back in the day when having a 100Gb fiber core was something exceptional... now days with 5G, that's on the edge out to the NodeB/Cells...
Welcome To SNBForums
