New Asus AC88U Bricked when installing Merlinwrt
izzner
Hi guys,
I was installing Merlin firmware and after successful upload the router rebooted
and went into a god knows what mode.
I cant get it to recovery(RESET button pressed for 10 sec +powerup)
I have done a hard reset using WPS button + powerup
Now i went and got a serial cable and connected it to the router pins.
I have access to CFE >
did CFE>nvram erase
Rebooted
No use
I just can not get it to ping my PC(192.168.1.11, 255.255.255.0) or the other way round
From My PC if I ping 192.168.1.1 i get timeout
Please Help
Check Youtube Link for whole bootup using serial/Putty
It shows
"External imprecise Data abort at addr=0x401ee3b0, fsr=0x1406 ignored."
Please Help it a brand new router and i just messed it up
Video of Bootup
Below is log File
https://drive.google.com/file/d/0B4Mg22SPeA8Lb1pEYnNNZ3JSRzQ/view?usp=sharing
You flashed the wrong firmware. This line indicates you flashed the RT-AC68U, RT-AC87U or RT-AC56U firmware:
wl driver 6.37.14.105 (r485445) failed with code 1
You need to use Firmware Recovery to flash the correct model - RT-AC88U.
You dont need serial cable and im sure your are not bricked
Try this with the good FW for your device.All you need is the Restoration Tool from Asus and enter the router in Recovery mode
Download the good fw(merlin or asus) and the restoration tool from Asus site
Press and HOLD RESET button and power on the router....Release power button but keep pressing RESET til leds flash slowly, you are now in REcovery mode
Look at my link, you need to do some steps after( this is for AC66, but it worked with my AC68 and N66)
ASUS Firmware Restoration version 2.0.0.0 = https://www.asus.com/us/Networking/RT-AC88U/HelpDesk_Download/
https://www.asus.com/support/faq/1000814/
That means you flashed the wrong FW (RT-AC68U) via Restoration Tool, TFTP or CFE mini server.
How do i get it to ping ??
The IP 192.168.1.1 doesn't work...
If it cant ping it cant do tftp...
if it cannot connect to LAN how to restore firmware...
can i get the firmware on a flash drive and mount it somehow ??
Did you tried the steps from POST #4? ... u need to put your router in RESCUE mode :)
You need after to change your NIC to a static one .. ex 192.168.1.2(in Windows network adaptor), IPV4,remove auto dns,
Then your start Restoration tool and reflash with the fw you want.... 380.58 or 59
When flash is done , go back to Windows and set your NIC to auto DNS like before
Ok i got to the console and can list mtd blocks
Please help me guys...
You just need to set your device to Recovery Mode and upload the right FW model file (RT-AC88U) and it's done.
Why do you try to ping the router?
Is the Power led in front flash slowly after 10 sec if you hold RESET after power on
Almost 3 years in that forum and i never saw someone complety bricked an Asus router. :)
You probly forgot one step with the rescue mode and flash
Have you done that?
Use the following DNS server addresses (192.168.1.2) the last digit must be between 2 and 253
subnet 255.255.255.0..
Apply
http://windows.microsoft.com/en-ca/windows/change-tcp-ip-settings#1TC=windows-7
Led should still flashing slowly
Instal and start "recovery tool"
when flash is done, put back DNS on AUTO and restart computer
You can't have the serial port connected, remove it.
1. Power OFF your router.
2. Press WDS without releasing it and POWER ON your router, wait 15s and you should see you WPS LED fast blinking, release the WDS button and wait a reboot.
3. Wait 1 minute and POWER OFF.
4. Press RESET without releasing it and POWER ON your router, wait 15s and you should see you POWER LED fast blinking (recovery mode), release the RESET button.
5. Set your NIC to static IP 192.168.1.xxx (.100 for example), open a DOS command line prompt and:
# ping -t 192.168.1.1
You should see a TTL=100 reply, that means you are in recovery mode.
6. Open tftp32/64 client, select the correct file and insert 192.168.1.1 host address, press PUT and wait file upload finish.
7. Wait 3m and power cycle it.
8. Welcome back RT-AC88U.
Have you done that?
Apply
Please check my last post i have uploaded a photo that shows device is in recoverymode(confirmed by putty).
I have done that and also cleared nvram using "nvram erase" from CFE promt as well as the console prompt
Can you see the POWER LED blinking after 4.?
What i dont understand is why the device cannot be ping in recovery mode...
Make sure you use LAN ports 1 through 4 with your recovery computer. 5 through 8 are on a different switch, which probably doesn't work in recovery mode.
