New ax88u Upgrading from Ac87U
Jason Southwell
Just got the ax88u. Did a little reading about nvram script but appears wont work anymore?
Am I going to have to start over with my static lan routes and port mappings?
Restore Router Model MISMATCH - ABORTingnvram-restore.sh 202002201627_RT-AC87U-MIGR Sat Feb 22 22:34:17 EST 2020 384.13_2 #Version=30.3.0 0 minutes and 0 seconds elapsed
@Jason Southwell, I don't think you tried the appropriate script for your specific needs?
You may be best to not use it when migrating from your previous router, depending on what model and firmware that was.
Ya I ended up just starting over. and backup the config now. Was worth a try though!
I was on 384.13_2 on the old router. ran the nvram-save -migr which is what I thought should have been correct. and then and the -hnd save as well.
