EdgeRouter 6
"The all new EdgeRouter 6 brings “high-performance at disruptive pricing” to a new level. With a 50% increase in performance compared to the EdgeRouter Pro, the EdgeRouter 6 delivers the performance your network needs. Paired with our feature-rich EdgeOS makes this a versatile tool in both Carrier-Grade and Enterprise networks."
- New Design
- (5) 10/100/1000 Mbps Ethernet Ports and (1) SFP Port
- 24V/48V PoE Output*
- 4-Core 1GHz MIPS64 Processor
- External 48V 1.25amp Power Supply
- Fanless
- Desk, Wall, and RackMount options**
* This beta product ships with PoE output options of 24V 2-pair and 48V PoE. The final production model will provide 24V 2-pair and 24V 4-pair output, the 48V output option will be removed.
** Rackmount included in beta store purchases only, it will be sold separately in production.
MSRP $179
Product Specifications
Dimensions 11.25" x 2.5" x 9.75"
Weight 3.45 lbs
Enclosure Characteristics Metal Housing with Black Powder Coat
Processor 4-Core 1GHz MIPS64
System Memory 1GB DDR3
On-Board Flash Storage 4GB eMMC, 8MB SPI NOR
Max. Power Consumption 16W
Supported Voltage Range 100V~240V 50/60Hz Universal AC adapter
24V: 27V~21V
48V: 54V~45V
Networking Interfaces (1) RJ45 Serial Port
(5) 10/100/1000 Ethernet Router Ports
(1) 1Gbps SFP Ethernet Router Port
(1) USB 3.0 reserved for future
(1) BT/BLE 4.0
PoE Interfaces *(5) 24V/48V Passive PoE Ports, 4,5+/7,8- *48V PoE output is only available with 48V power adapter
Mangement Interface (1) RJ45 Serial Port
(6) Ethernet Ports, (default eth0)
