News New Eero WiFi 6 Tri-Band
Wonder how the antenna configuration is setup. Might be a good value.
My only concern is privacy given amazon.
Antenna design and internal photos will be off-limits for some time, per the Confid Request they submitted on 9/11:
I'm guessing they stuck with 2x2 radios, as that may have required less re-coding of the firmware/software stack.
Regardless, the main value add will be gigabit (-ish) backhaul (with Pro at least) and a bit more fronthaul per client.
More likely, for cost and physical size. With mesh, range is less important.
"Wi-Fi 6 tri-band concurrent 2:2:4 (802.11ax)"
Wouldn't this indicate 2x2 on 2.4 and 5.2 and 4x4 on 5.6?
