New GT-AX11000 Issues
Edward Gomez
Hi All,
I just migrated from an AC-3200 running Merlin to the GT-AX11000. I am running ver: 3.0.0.4.384_8011. Since I upgraded the firmware prior to configuring the unit I am seeing the following issues now that it's up and running:
1. AIProtection - I have it enabled but I am not getting any hits on any of the counters across the board. They are all 0.
2. DDNS: The status on the certificate stays at authorizing. I believe that this may be broken from some of the threads but wanted to check.
3. OpenVPN (Server) - I duplicated my configuration but am unable to connect from the outside. I can connect internally via Wifi. I tried the same test with IPSEC. Looks like something is blocking external access.
Have any of you run into these issues?
Thanks!
Hi All,
Thanks!
1. No issue really?
2. Cant confirm any problem with ddns. I have been running with working ddns with all firmwares so far.
3. If your dynamic DNS does not work, then your VPN server wont work either. The routing will not work. Thats why you cant access it from internet.
Cheers
