Hello,
New to SNB and new to network structures (if that is such a term). In the past internet needs have been really simple - ISP router in bridge with router behind that supplies WiFi to laptop and that's it. Files and Music are currently housed on USB drives. I work from home and use a VPN at the laptop level except for banking as I have connection problem with my bank when using the VPN.
New home and now a new household dynamic.
The new system will need to support a smart TV plus a second TV with a Amazon stick, cell phones (qty 2 on WiFi when at home), XBox and 2 laptops. Will add a NAS box at some point (plan is to hard wire the NAS and be the primary data (files and music) depot with the USB drives to be the secondary backup)
1) best way to layout connections? Thinking I'd want to isolate the smart TV and the Amazon stick away from everything else - would a VPN be a good consideration as well and where would I put the VPN? at router level? or at device level?
2) I could put the laptops on their own WiFi with the cell phones.
3) If the VPN is at router level but if I continue having bank connection issues maybe a separate WiFi for banking only?
4) where to put the NAS box?
Suggestions or comments on where to start, any additional hardware, software.
Thank you..
Thank you..
