New iRobot i7
coxhaus
Part of the Furniture
I have my new iRobot i7 vacuum. It has the same issue as posted under my 960 thread for in that it does not pull an IP address. I have to add a static IP and then it works fine. The i7 works with a larger home over the iRobot 960. After you clean with the i7 for 4 or 5 times it builds a map of your house. You then can assign names to the different rooms. I like this feature. Running a complete clean takes 5 or 6 hours for my home which is too long in my opinion. Now I can tell it to clean certain rooms which reduces the run time. This works much better in a larger home. Wireless does not seem to be a problem as the unit roams across my Cisco APs.
Are any of you running one of these?
