New Port 1198 for PIA with RSA 2048 certificates using Merlin Firmware
yorgi
Private internet access has added a new port 1198 with RSA certificates
its a bit tricky to set it up but here simple steps on how to do it.
Look at the pia.jpg I have attached to setup the configurations.
you need to enable ssh in administration system and Format JFFS partition at next boot
Then you need to enable SSH with with file protocol SCP using WinSCP
download this zip file from
https://www.privateinternetaccess.com/openvpn/openvpn.zip
extract the openvpn.zip file and copy crl.rsa.2048.pem and ca.rsa.2048.crt to jfffs/config
once you have done that.
add these lines to custom configurations on VPN client
crl-verify //jffs/configs/crl.rsa.2048.pem
ca //jffs/configs/ca.rsa.2048.crt
Start the client and you are ready to go :)
