New R8000 Firmware
twennywonn
Release Notes
1. [New feature] Supports Bridge/VLAN Settings
2. [Bug fix] Improves the wireless connection stability.
3. [Bug fix] Fixes the IPv6 auto detection issue in certain cases.
4. [Bug fix] Fixes the WPS connection issue on the second 5GHz WiFi band.
5. [Bug fix] Corrects the Chinese website link address: www.ORAY.cn
6. [Bug fix] Fixes the issue in which Samba overwrites large files incorrectly.
7. [Bug fix] Fixes the wireless throughput inconsistency issue.
8. [Bug fix] Fixes the Intel AC7260 connection issue when computers and tablets are on power save mode.
9. [Bug fix] Improves the interference resistance at 5 GHz.
10. [Bug fix] Fixes the IOT issue for some USB 3.0 storage devices.
Just go into the router Advance Settings for Update and let it check. It finds it and update from there.
Bob Silver
Netgear Networking Consultant
still no QOS hahahhaha the 4Q is almost over..
I believe Netgear will be adding the Dynamic QOS that is in the 7500 to the 8000 and the 7000. That will be coming early Q1. Worth the wait IMHO.
Bob Silver
